Shifter just a' rattles
Damn my shifter is becoming rather noisy its the pro 5 0 and under hard accelration it rattles like a bitch. im sure its just the stick with metal against metal cus my buddys did the same thing from when he went from the stock stick to the louzs short stick, cus that rubber bushing aint there any more. is there anything you can do to fix this? its not like its loose or any thing just metal on metal vibration.
This took care of a lot of it for me.
https://ls1tech.com/forums/manual-transmission/265250-dynamat-shifter-vibrations-install-pics.html
You could use the dynamat method, or you could make a gasket for the base of the shifter. The noise comes from a combination of both the base of the shifter and the shifter stick to shifter contact. Use your old shifter as a template to make a gasket for the base of the shifter. You can find the paper gasket material from Pep Boys, it's pretty inexpensive. For the shifter stick to shifter vibration, just buy two bolts about 1/4" longer than your current bolts, and buy some nuts to go with them. Replace the existing bolts holding the shifter stick to the shifter with the longer bolts. Then, with the protruding threads on the passenger's side of the stick, use the nuts and tighten them down. Using both the gasket for the base, and the longer bolts/nuts for the stick will reduce the rattling noise by about 95%.
Originally Posted by Mark A. Rogalski
Krab,
Why will a 1/4" longer bolt eliminate vibration?
https://ls1tech.com/forums/showthrea...hlight=shifter
I guess I can't explain it too well in words, but I know it works from experience with my car. Hope this info helps someones noisy Pro 5.0.
I have the Hurst Billet and noticed that the sides that touche each other(shifter rod & shifter stick) are ribbed so they lock in place. It did come lose once so I used a little loctite. I also used a cork gasket along witht the Dynamat.
