Top bolt on the bell housing
A bunch of really long extensions and a swivel. Come in from the back of the tranny with the long extensions and the swivel and you should be able to get to it pretty easy.
Dan
Dan
What they all said + a whole lot of cussing. In process of clutch swap and putting back the pieces, my problem with the bell housing was the top bolt and the one to it's left. Wire bundle was in way of top bolt so had to push it with an extension while setting the socket w/ u-joint and extension in place. The top left one....I just pray I got it tight enough....no room between it and the transmission hump.
I can get that bolt off in about 1 minute with either a wobble extension and a regular socket or a Snap-on brand wobble socket. Snap-on wobble sockets are ball and socket style wobble NOT the universal joint type wobble(they dont work for s&%t).
