Clutch alignment????? (CarTek)
Old 03-11-2002, 01:52 PM
MAFs 00 Ws6's Avatar
Default Clutch alignment????? (CarTek)
Ok so I am out looking for an alignment tool, but noone seems to have one for a 2000 T/A. The only way that I can get one is if I buy the complete clutch kit. Called cartek and they told me that I should just buy the universal and use that. Everyone who has installed a CarTek clutch what did you use for the alignment? Please help... <img src="images/icons/confused.gif" border="0"> Michael
Old 03-11-2002, 02:22 PM
1madss's Avatar
Default Re: Clutch alignment????? (CarTek)
Ask for a LT1 tool, it is the same. I got mine from Pep boys for about $2
Mark
Old 03-11-2002, 02:30 PM
So the LT1 alignment tool will work on the '00 T/A?? I know that they had one for a '98 will that work?? Thanks..Michael
Old 03-11-2002, 03:22 PM
1LE
1LE's Avatar
You could just go to auto zone and get a clutch alignment tool there, it has 8-10 different size ends that screw on and it works well. It's only like 12 bucks and will work for any of your future projects <img src="gr_stretch.gif" border="0">
Old 03-11-2002, 05:00 PM
1madss's Avatar
Yes the 98 tool will work. All you need is to have the right number of splines and input shaft diameter. The LS1 and LT1 are 26 spline with a 1 1/8" diameter shaft.
Mark
Old 03-11-2002, 07:55 PM
I can shift faster than you.
Jason99T/A's Avatar
As Mark said, the LS1 and LT1 alignment tools are identical. I have both and use the one I can grab first. <img src="gr_images/icons/wink.gif" border="0">
Old 03-12-2002, 06:58 AM
you guys rock...thanks...MIchael <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old 03-12-2002, 07:41 AM
cablebandit's Avatar
I havent used one in several years....i just eyeball it if I dont have a tool available. Done 2 so far on a ls1 <img src="gr_stretch.gif" border="0">
Old 03-15-2002, 07:36 AM
Just want to say thank you for the information on the tool. I picked one up on Wednesday fits perfect.... 1 1/8'" 26 spline .. Just can not beleive that this freakin tool was 12 bucks, probably cost them 1.00 to make if that... <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> thanks again everyone you guys really ROCK!
Michael <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Quick Reply: Clutch alignment????? (CarTek)
