pilot bearing trashed, what was yours like
well my shop got my trans out to day, and he was telling me that my pilot bearing was trashed. (i dident see it i should have asked thoe)
would that also cause the shaft to rub the salve and cause it to leak?
he also said it could have a effect on teh crankshaft....that true?
98 with 84k on it, i got it with 75k so im not sure on the history
With the Pilot Torn up the cause could be Trans Mount, Motor Mount, Broken or Twisted Bellhousing. The Main cause is a Misalignment in the driveline. The effect on the Crank is if it was caught early than don't worry as long a a new one seats correctly you will be ok. If not than you will be looking at replacing the crank.
Thanks,
BrakeandClutch
Parts & Service Since 1938
Thanks,
BrakeandClutch
Yea I had the same thing happen to my pilot bearing, completely trashed, no needle bearings left, it roughed the input shaft up a little bit, but luckily the damage was minimal and we were able to just to clean up the shaft and put it all back together.
i dident feel any thing wired at all when i was still driving it.
i drove around with it poping out of 4th for a couple on months.
and i went to drive it one morning and clutch stayed at the floor and i could never get it back up, and fluid was pouring out the bell housing.
so out of 100% whats the chances that a new crank is needed.
im 19 and after 8months of 40+ hours each week (and thats still paying 400 in bills each month) i got just enough.
and im out of $$ and this is keeping me from going and getting another job.
im scared
im scared
im scared
im scared
I always try to talk our customers into the solid bushing part # Chicago Rawhide PB656. I have seen plenty of failures on the needle bearing type part # Chicago Rawhide PB657. From what I can tell the solid bushing type can handle the flexing of the input shaft & other components better than the needle bearing type. Just my 2 Cents....
Thanks,
BrakeandClutch
*Quality Parts & Service Since 1938
Thanks,
BrakeandClutch
Most of the people on this board are only using the Needle type because that is what came from the factory or what comes in the kits they buy. We see far more of the needle type in terms of failure for that application. Even the newer Chevy Trucks we sell clutches for are now using the Needle type and they just don't hold up to the old solid type. Back in the old days you just put a little anti-seize on the end of the shaft, stuck er in & away you went & the old solid type was fine. But remember that the Solid type is not a fix all. If there is a misalignment it will still fail, it just will take longer to do so than the needle type.
Thanks,
BrakeandClutch
Thanks,
BrakeandClutch
