car wont go in gear after line lock install..
ok, i installed my line lock today. its a pos. i dont know what it did wrong, but it was not holding the car for ****. well i was going to drive off and i couldnt go into reverse. i removed a power cable and it sparked cause it grounded, but i was hearing a grinding sound when i tried to go into reverse and it just does not wanna get in gear smoothly. anyone have any ideas what it could be? once its in gear, its fine, but its going into the gears and reverse that i have my problems.
Originally Posted by ninobrn99
well then i guess im gonna try to get that replaced! any idea how much they cost? i wonder how im gonna replace it. do i have to drop the tranny?
Ayyyy, my furry little friend. The line lock has ABSOLUTELY nothing toi do with the tranny. Its just a coincidence that it happened right after you installed it.
the problem you are having is that the clutch is not disengaging all the way. Its usually a problem with your hydrolics. Air, a leak, one of the cylinders going out or something like that.
The the reverse lock out solenoid would cause your shifter to be hard to push OVER but not up into reverse and there would be no gear chattering either. AND this would not effect any other gear.
You're lucky i came into the M6 forum i never come in here. i just saw your name and clicked on this thread.
you know, i thought my master cylinder may be going out cause its been feeling really soft lately. why would the line lock not hold the car though? i guess its a good thing i got the ram master cylinder
Originally Posted by SUX2BU
DON'T DO IT. That has nothing to do with it.
1 Post
well i cant put it in any gear with the car on. when i have it off or with the key to accessory its fine. i can get in any of them, but i cant do it with it on. when i try to put it in gear, it wont budge, but when i try to push it in 1st, it makes the car move foward a bit and the same goes for reverse. any thoughts??
I do agree with the above thread....do't think it's anything more than a coincidence. The hydraulics on the clutch have zero in common with the linelock and brake system.
I'm in the middle of a master cylinder replacement on my car now....I'll let you know if this fixes these symptoms.
juan, how do i bleed it with a mityvac? im almost done installing my new master. just gotta hook up the quick disconnect. all the fluid came out of the resevoir so i know there's air in it.
oh, i installed it already, i filled the resevoir with fluid, then pressed the quick disconnect side in to let the fluid through. will that not work? do i need to uninstall it and do it over?
right now the m/c is very very soft, so i know the fluid hasnt ran through it completely, but it just circulates right? resevoir->m/c->slave and back? so after enough times i should be able to get it all out right?
