Pilot bearing removal/install
What is the safest way to remove the pilot bearing? I know there is a tool that can be borrowed/bought, but a part number and/or link would be great.
I don't want to screw this up so please help me out
If possible, see if you can find an autozone that rents a blind hole puller. It is very sturdy and made it a breeze to remove. I have heard of others breaking the pilot bearing puller(it seems to be much more flimsy) from autozone.
The deposit is $140, but you get it back when you return it.
DEE
DEE
UNDER PRESSURE MOD
A quick question. I pulled the transmission this weekend, but left the bellhousing and clutch installed.
I reach in and was able to see that the pilot bearing is probably going to need to be replaced since it's as good a time as any to replace it. The inner race seems pretty loose so I will be going with a bronze bushing.
My question is, can you pull the pilot bearing without removing the clutch and bell housing? Granted, it's another 20 minutes to pull the bell housing and clutch, but its just that much more of a pain when putting everything back together.
It looks like I might be able to do it, but I wanted to hear other peoples stories and maybe see some pics as well.
Alchemist, I cannot say for sure if you can get remove the pilot bearing with the clutch and bellhousing on. Just go rent a 'blind pulley puller' from autozone (that's where I rented one) and try it. If it can't reach with the clutch and bellhousing on, you will then have to remove it. Good luck!
UNDER PRESSURE MOD
Originally Posted by purple98haz28
i used a blind hole puller worked like a charm
Could the bad pilot bearing been that ticking sound I've been hearing???? The sound was coming from the back of the motor, so I guess it could have been the pilot bearing or the throwout bearing.
We'll see after the tranny gets rebuilt and the bronze bushing goes in.
UNDER PRESSURE MOD
Originally Posted by peterock98
Nope you can't remove the pilot bearing with the clutch in there.
