Ticking Noise Of Death!!!!!!!!!!!!!!!!!!!
Old 02-16-2006, 10:05 PM
nikeair042's Avatar
Default Ticking Noise Of Death!!!!!!!!!!!!!!!!!!!
I have this damn ticking noise ever since I had a new clutch put in. Like, any MPH over 30 and you can here a slight, metalic sounding ticking from the shifter area. As you go faster, the ticking speeds up and gets a little louder. Its getting annoying....any help?thought?suggestions?
Old 04-11-2010, 04:48 PM
tbenedict's Avatar
Did you ever figure this out? I just replaced my clutch and flywheel and have a strong ticking coming through the shifter, primarily when I'm off the gas. I also think my right rear brake is sticking (would have just happened).
Wonder if they could be related...
Old 04-12-2010, 03:26 PM
99ssleeper's Avatar
you have a zip tie rubbing on the driveshaft. they hold the e-brake cables and it's very easy to get one stuck above the d/s when reinstalling it.
Old 04-12-2010, 03:34 PM
99ssleeper's Avatar
lol...the OP is 2006!
Old 04-12-2010, 07:03 PM
tbenedict's Avatar
Hey, I was using the search function and the question was never answered. Must be a strong zip tie to make that kind of tick without ripping off.
Old 04-12-2010, 09:29 PM
Hashish's Avatar
Zip ties are FTW
Old 04-14-2010, 08:24 AM
99ssleeper's Avatar
I know, just giving you some crap.
Yes thay are strong, they are the style that is about 3/8" wide. When they tie them, they dont cut the excess strap off which is about 5" long...enough to rub on the d/s and click.
Old 04-14-2010, 08:34 AM
tbenedict's Avatar
I checked and didn't see any. I found the ball joint in exhaust slightly touching the body. Fixed that, but I still have something metallic touching that I couldn't see in the right rear. Will have to dig into that nexts.
I believe the shifter ticking is coming from the shifter itself now. It is hit or miss when it happens and I think I feel a hint of play in the joint of the shifter.
