P/N for GM master cylinder rebuild kit...
I need a rebuild kit for my master cylinder BAD. I'm hoping someone out there might have a part number... Anyone?
Thanks if you can help!
Ben T.
Ben T.
I'm not absolutely certain but I think they're not rebuildable - you need to buy a complete new mc. The part number for the 01-02 (upgraded) mc is 12570277.
Originally Posted by jmd
You could do it, but would need to source the o-rings to do it. The piston is held down with an inner snap ring.
Since I believe the stock 01 master is same i.d. as the McLeod, their rebuild kit may partially fit the OEM master, but I have not tried this.
I'll have to stop by TR and check out one of those rebuild kits.
Ben T.
