Spec 5/Shimed Slave- Big Problems
My friend just installed a Spec 5 with the flywheel that comes with it into my brand new T-56 built by Rodney @ Rpm Transmissions. He installed the shim that comes with the kit and says in the instructions to put in a f-body. Well after trying to drive it the clutch doesn't engage at all and the car is not drivable. It doesn't grab and when the clutch is totally out and accelerating, the clutch takes all kinds of abuse (just spinning), and the motor doesn't get very much power to it. Were thinking that is has to be the shim that is causing the problems and were ticked off that we have to take the whole tranny out to fix it. Any similar experiences or commets welcome please. Thanks.
I remember that we had to get a little longer bolts with using the shim on my SPEC 3. Also if that shim isn't lined up correctly you will have problems. After dropping the tranny 3 times b/c fluid was leaking from the bellhousing and getting no pressure on the clutch pedal, we couldn't figure out why. On the last go around, we saw that the shim wasn't lined up correctly, fixed it and everything was perfect.
get an adjustable master, or just make your stock master adjustable. its VERY easy to do and will solve your problem. just cut the rod end off, thread the rod and buy a threaded female rod end.
i just installed a spec 5 about 3 or 4 weeks ago, mine came with a steel shim and i installed it, i bled the system very well. all seems good and has a good feel and it grabs like a ****. try bleeding the system again before you pull the tranny back out. i like the spec 5 except for the damn squeeling when i take off.
LS1Tech Sponsor
How many times have you replaced the slave bearing? The reason I ask is becaue when you change it there is a metal washer that ussually stays on the the slave assembly,that has to be taken off or else it acts like another spacer for the bearing causing your problem.
We did my buddy's throwout bearing 4 different times throughout the years and the last time the clutch would not engage.I pulled it apart and removed 3 washers from the slave assembly that were left there from previous throwout bearings.---problem fixed.
I'm not really mechanically inclined but my friend who is doing my tranny is, and i ran all of those options by him and nothing that was suggested was the problem. Thanks for the suggestions though. He is almost 100% positive that it is the shim causing the problem but is just furious that he has to pull the tranny out again. The shim probably doesn't work becususe for some reason the dimensions insuide the transmission is different than what most are.
LS1Tech Sponsor
Removed the shim and clutch works great. It is very, and i mean very grabby, but thats what i wanted. It'll squeek most times when taking off depending on how you let the clutch out. Its more of a chirp than a squeal, it kinda sounds like your chirping the tires. It also chirps when shifting gears but overall i love the clutch so far.
