Transmission Won't Slide All The Way In
Old 04-15-2006, 07:15 PM
rare bird's Avatar
Default Transmission Won't Slide All The Way In
Having trouble sliding the trans all the way up to the bell housing (still about 1/2" away. Any thoughts on what might be causing this? The pilot tool slipped in fine after the first attempt, rechecked again after pulling the tranny back. The clutch is a spec 2+ w/ a fidanza flywheel, new pilot bearing is in. Also bent up the rear lip of the shifter hole in the tunnel for more clearance. The gap between the trans & bell housing measures even as far as I can measure around it. A little frustrated at this point, this is far from my first clutch job. It almost seems like the input shaft is'nt going into the pilot bearing, despite how straight the tranny seems to be going in. Any thoughts on this would be greatly appreciated.
Old 04-15-2006, 08:21 PM
Deeavi's Avatar
I am having the same problem. Mine is about 1 inch out and will not go any closer. I have pulled everything to check alignment, so that is not the problem. It is like the slave cylinder is holding it out.
Old 04-15-2006, 08:39 PM
Ferocity02's Avatar
It's tough, just work with it though.
Old 04-15-2006, 10:07 PM
MetallicaMatt's Avatar
i'm having the same problem, i'm about 1 1/8" away from the tranny and bellhousing
i cannot get this thing to budge...any tips?
Old 04-15-2006, 10:37 PM
Farmer2's Avatar
Try either pluging in the master cyl hose or opening the bleeder to the slave to releive the preasure.
Old 04-15-2006, 10:40 PM
chpmnsws6's Avatar
did you lude the alignment pins up? also, make sure some of the fluid is not binding the slave up (common problem with installs)
Old 04-15-2006, 10:53 PM
rare bird's Avatar
The alignment dowels are not quite entering the holes yet, so that's not holding it up. Also I did'nt crack open the bleeder yet (although I'll try it) but I don't think that slave cyl. spring is holding the trans back. I'll try that in the morn.
Also there is no hydraulic line connected to the slave yet.
Old 04-15-2006, 10:57 PM
chpmnsws6's Avatar
Also double check to make sure all is 100% lined up. After a good nights rest should help things go smoothly
Old 04-15-2006, 11:08 PM
i'm in the same boat, no hydraulic lines connected, i'll loosen the bleeder valve tmr
problem is now i'll be by myself with it being easter
I wonder if i should go buy a tranny jack...hate to spend the money on it though
we pushed as hard as we could and that sucker wouldn't go in, maybe there was pressure in the OT bearing... i dunno
everything is lined up 100%
Old 04-15-2006, 11:18 PM
rare bird's Avatar
I have a 1/2" all around as far I can get my 6" scale. Does anyone think the slave spring has just enough pressure to make things difficult. Does anybody recommend starting the bolts to draw the trans in?
Old 04-15-2006, 11:19 PM
chpmnsws6's Avatar
man i wish you lived closer to Lima Ohio man! we could get that thing done by the AM
chpmnsws6's Avatar
we always do that, just don't torque them to hard
Old 04-15-2006, 11:22 PM
rare bird's Avatar
Ya, I wish you lived closer to Grand Island NY. I was able to get a couple bolts started but not the others, it just did'nt feel right.
Old 04-15-2006, 11:30 PM
chpmnsws6's Avatar
you'll get it. just take a break or to and go do something else. 9 times out of 10 you'll go back and it'll slide right in........ its the hotrodders curse
Old 04-15-2006, 11:37 PM
rare bird's Avatar
Maybe the Easter Bunny will have it in by the time I wake up tommorrow.
Old 04-15-2006, 11:39 PM
chpmnsws6's Avatar
Old 04-15-2006, 11:44 PM
rare bird's Avatar
So much for that idea. I think that was my basket.
Old 04-15-2006, 11:49 PM
chpmnsws6's Avatar
Sorry bud, just wanted to make sure you weren't getting your hopes up. HAHAHA
Let the slave blead down some, as i think that might just be your problem. Last time we put my tranny in (4th time maybe?) it wouldn't go in so i got pissed and just started shaking the hell out of it while lifting it up and it slid in just enough to get the bolts in 2-3 threads. Then just even pressure on the bolts while still shaking the tranny around
Old 04-15-2006, 11:52 PM
rare bird's Avatar
You did that shaking thing to, huh?
Old 04-15-2006, 11:53 PM
yeah i wish i was closer to lima now!
i can't find a tranny jack for cheap
looks like this might be sitting until next weekend
Quick Reply: Transmission Won't Slide All The Way In
