Clutch and flywheel install, a little pricey?
Old 04-20-2006, 10:35 PM
michaelg589's Avatar
Default Clutch and flywheel install, a little pricey?
So i just dropped my 2000 Trans Am off at a local garage yesterday to have a new SPEC clutch and flywheel installed, and to have one of my front signal light sockets replaced. The guy calls me today and tells me the estimate. about 740$ for everything! I was shocked. He is saying that its an 8 hour job and he charges 65$ an hour. Also he said that I should replace the slave cylinder, which I agreed on, and that was 170$. Is changing a clutch and flywheel really an 8 hour job?
Old 04-20-2006, 11:22 PM
Shamson5.7's Avatar
Took my guy 2 days. He didnt work on my car straight through though. New clutch/pressureplate/flywheel and mastercylinder/slave cost me 650 to install.
Old 04-20-2006, 11:28 PM
Slow00ls1T/a's Avatar
was it a dealership or a reputable (sp) lsx shop bc that can change the rates alot and how many hours of work it is.
it took my brother 8 hours to do it at his dealership and this was his first time, we installed headers and y pipe in those 8 hours
Old 04-21-2006, 10:30 AM
its not any kind of reputable lsx shop, its just a local garage. Pat's Auto repair. I already told him to do the work. It should be done either today or tomorrow morning he said. At least Ill have a good clutch for a long time now.
Old 04-21-2006, 11:24 AM
JimMueller's Avatar
The local sponsor charged me $85/hr and approximately 8 hrs labor to swap the master cylinder, slave, and clutch.
Old 04-21-2006, 11:27 AM
black01_WS6's Avatar
cost me about 300 for labor
Old 04-21-2006, 12:54 PM
NHRATA01's Avatar
There's a few LS1 shops in NJ. Usually charge about 350-400 for a clutch job on an Fbody.
Old 04-21-2006, 02:18 PM
Starz T/A 17's Avatar
It took my around 10 hrs but that was without a lift and many trips back and fourth to the parts store to get misc. stuff, so yeah its probally right around an 8 hr job
Old 04-21-2006, 02:32 PM
urbanhunter44's Avatar
I can do a clutch in my car on the lift in 3 hours tops if im going slow and bullshitting with people. Hell I can yank an auto in 40 minutes by myself, and put it back in 30 with some help.
Old 04-21-2006, 05:39 PM
LastHawk02's Avatar
yeah i got quoted about 225-300 sounds alil pricey to me
Old 04-21-2006, 05:40 PM
INMY01TA's Avatar
New slave is like $80 I believe.
Old 04-21-2006, 05:50 PM
fletchls1's Avatar
Upgraded slave is $17X.XX
Old 04-21-2006, 05:53 PM
INMY01TA's Avatar
Upgraded to what? Back in 02 I paid $85ish for a factory replacement from the dealer.
Old 04-21-2006, 10:15 PM
fletchls1's Avatar
I ordered my clutch from clutchexpress and they gave me the part # for the slave I should use...Took it to gm and they told me it was used in larger pick-up trucks..The bill i was handed was 170$$ some odd dollars for the part.
Old 04-21-2006, 10:35 PM
8a8mfh's Avatar
Damn, it took me about 14 hours to switch from an automatic to a manual trans.
The GM flywheel, pressure plate, disc, pilot bearing, slave assembly cost me $540.
Old 04-21-2006, 10:43 PM
endub6's Avatar
I was charged 230$ for clutch,flywheel, pp install. Just labor.
Old 04-22-2006, 10:47 AM
INMY01TA's Avatar
Hmm, I guess I'm wrong then. Maybe price has gone up tho as we did mine 3 or 4 years ago. BTW, I only paid $250 labor for Mcleod clutch+flywheel install. Thats including the master cylinder.
Old 04-22-2006, 11:44 AM
mrhzk35404's Avatar
Mine was free. I did it my self.
Old 04-22-2006, 12:25 PM
jwitt2's Avatar
+1
turn the wrench yourself if you have the time.
Old 04-22-2006, 02:10 PM
JDP
JDP's Avatar
740 seems high, they charged me at a trans shop 300 to change out a trans and do a clutch on a front wheel drive car.
how hard is it to change the cutch on these cars.
ive done my 86 mustang 2 times, my buddies mustang 2 times, and ive done a 95 stang once, and mustangs are easy to do, but how much harder is an f-body, because im not going to do it if its going to be a pain in the ***
