Could bad motor mounts make clutch chatter worse?
Had my Spec 3 for about 8k miles and still get a little chatter when taking off in first. Could worn out motor mounts amplify the clutch engagement chatter, or cause chatter if there were otherwise none?
thats not what i want to hear. my engine moves about 1"-1.5" when i am on the brake gas and let out the clutch. mine chatters quite a bit. i figuered it was making all the noise cause the motor was going up and down and smaking the mounts. oh well i still need to get some poly mounts.
Yes, I had a small shudder as I released the clutch. I bought a new motor mount and filled the void area with 3M Window Weld. Had the passenger mount replaced and the shudder is gone. Surprisingly, I asked my mechanic about the old one and he said it didn't look too bad. It wasn't torn loose. I had the drivers side replaced previously.
