how to take apart T56?
Old 04-30-2006, 07:53 PM
Syxx613's Avatar
Default how to take apart T56?
hey guys, ive got a T56 from a 99Z sitting in my room here but ive never had one apart before. how do i go about this? i took out some of the bolts near the end shaft but cant slide that whole part off because of the shift rod. how do i get the rod out of the way? thanks!
Old 04-30-2006, 08:47 PM
1LoudTA's Avatar
barnes and noble sells an entire book with pictures on the disassembly and rebuilding of a manual transmission. $19.50 buy it
Old 04-30-2006, 09:16 PM
wrencher
wrencher's Avatar
Wanna sell it?
Old 04-30-2006, 09:25 PM
SScam68's Avatar
you can download it for free
Old 04-30-2006, 09:38 PM
Syxx613's Avatar
i found it and am reading now, thanks!
Old 05-01-2006, 11:30 AM
'02 SLP#686's Avatar
Pretty easy. Just a bunch of snap rings and gears. Gonna need a press and a nice bearing tool for the press. Pulling 6th gear is the hardest part (puller w/LONG arms - I made my own). It is easy to chip the edge of the gear - if you do, don't worry about it, unless the chip is in the middle, you will never feel it
Old 05-04-2006, 06:38 PM
SMonty's Avatar
How hard/expensive is it to rebuild yourself?
Old 05-04-2006, 08:01 PM
bmfcamaro's Avatar
http://www.ls2.com/forums/showthread...threadid=30484
Old 05-05-2006, 01:22 AM
waltsfastz's Avatar
amen to all of that, I too made a handy little puller.
BTW the shfter socket is held in by a roll pin, You can drive it down and then slide the shifter socket off
Old 05-05-2006, 09:22 AM
NOIR's Avatar
It's all alien technology I say!!
Good luck lol, those things are impressively complex in appearance.
Old 05-05-2006, 10:13 AM
Complex in appearance, but easy as long as you keep stuff in order. A blown apart picture is always a plus.
Quick Reply: how to take apart T56?
