which clutch
Old 05-05-2006, 10:13 AM
dub.ya.es.SICK's Avatar
Default which clutch
Ill probably be throwing 450rwhp which clutch do you think I should get ls7 clutch or dual friction centerforce? no spec or no ram thank you.
Old 05-05-2006, 05:21 PM
00TAProject's Avatar
Your best bet should be the Textralia....My buddy has it in his and he says that it hooks hard on hard launches but is extremely drivable....
I am going with the same clutch as well....
Old 05-05-2006, 06:45 PM
JLMoses's Avatar
textrilla hasnt really been out long enough to hear anything bad about it yet...if there's anything to hear about it..lol...but i'm hopin to get it as long as the price will come down a lil....
Old 05-06-2006, 05:46 PM
MY(LS)won's Avatar
what's the price on one, and where can i buy one!
Old 05-06-2006, 05:48 PM
JLMoses's Avatar
when i checked around 950....Textrilla is a sponsor... >>>
Old 05-06-2006, 06:05 PM
silverTA2002's Avatar
Textrilla- around $950
LS7- around $450 (ls7clutchkit ls7 clutch and ls2 flywheel)
Old 05-06-2006, 06:16 PM
Y2K SS's Avatar
Had um all and just installed my Textralia. By far the best clutch I've ever had so far. No chatter.... no shifter vibration that I had with the others and smooth as hell.
Old 05-06-2006, 06:48 PM
Rynofasho's Avatar
Time to update that sig
Old 05-06-2006, 06:51 PM
Y2K SS's Avatar
thanks.... lolol
Old 05-08-2006, 10:16 AM
angelR's Avatar
Would the ls7 setup be up to 450 rwhp and more importantly about 410 rwtq for long? It would be in a vehicle that weighs maybe 2700 lbs with driver and would have a 3.9 rear gear. If not what would you reccomend as the most cost effective setup?
Old 05-08-2006, 12:53 PM
rob c's Avatar
My guess would be yes...seeing how the Z06 w/LS7 makes about 530hp at the crank, if you believe some of the stories...
Old 05-08-2006, 03:02 PM
GR33N GoblinM6's Avatar
I have center force dual friction.. that bitch is getting changed out ASAP.. rattles and vibrates above 3200rpms.. im going the LS7/LS2 combo
Old 05-08-2006, 04:03 PM
Tobynine9's Avatar
so that vibration coming through my Ripper is from the clutch?
Old 05-08-2006, 04:13 PM
angelR's Avatar
I figured that would be the case. And is why I am looking at using the above on my setup... unless I find a really good deal on something aftermarket.
Old 05-08-2006, 09:12 PM
JLMoses's Avatar
any thoughts of Textrilla coming down in price or offering a lower price in a group purchase? just a thought...
