Recall on LS7 Clutch's ????
Old 06-30-2006, 02:16 PM
rickJames's Avatar
Default Recall on LS7 Clutch's ????
Did GM post a recall on LS7 Clutch's? I am in the process of purchasing a new clutch and want to know if here are any issues with these. The kit is going on a 98 Z28 with an estimated 420 to 440 rwhp. Thanks
Old 06-30-2006, 04:28 PM
BIG_MIKE2005's Avatar
Not that I have seen or heard of. I would think the sponsors would post up for all their customers if their was one.
Old 06-30-2006, 07:27 PM
rickJames's Avatar
I did some research and found the following
"Quoted from corvettefourm.com"
http://forums.corvetteforum.com/show....php?t=1346975
GM Parts Bulletins & Information – To Chevrolet Dealers
GMP06-060 – Customer Satisfaction Program #06523 Engine Flywheel/Clutch Interference
DESCRIPTION:
CUSTOMER SATISFACTION PROGRAM #06523 – MARCH 27, 2006
THIS RECALL IS IN EFFECT UNTIL March 31, 2007
 Certain 2006 Chevrolet Corvette model vehicles equipped with 6.0L V8 (RPO LS2 - VIN U) or 7.0L V8 (RPO LS7 – VIN E) engine and manual transmission may have a condition in which the flywheel may have been incorrectly machined, resulting in insufficient clearance for clutch cover self adjustment, reducing clutch life.
 This program will expire on March 31, 2007.
 Dealers are to inspect and, if necessary, replace the engine flywheel.
 Refer to Customer Satisfaction Program #06523 for further information
EFFECTIVE DATE:
Initial owner mailing is scheduled to begin: 4-3-06
GENERAL INFORMATION:
Parts required to complete this program are to be obtained from General Motors Service Parts Operations (GMSPO). Normal orders should be placed on a DRO = Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO = Customer Special Order.
Part Number Description Quantity/Vehicle
12571611 Flywheel, Eng 1
IMPORTANT: Due to the small number of vehicles involved and due to limited initial parts availability, Dealers are encouraged not to order program parts for use as shelf stock. Parts should only be ordered when inspection determines that it is necessary to replace the flywheel.
It looks like this only applies to the LS2 flywheel on some Corvettes. Im assuming the OEM replacement parts in stock do not have the same flywheel issue. I hope this is the case because i just ordered the LS7 cluthch package.
Old 06-30-2006, 07:32 PM
rickJames's Avatar
More information:
CONDITION
CORRECTION
VEHICLES INVOLVED
Involved are certain 2006 Chevrolet Corvette model vehicles equipped with 6.0L V8 (RPO LS2 -
VIN U) or 7.0L V8 (RPO LS7 – VIN E) engine and manual transmission and built within these
VIN breakpoints:
2006 Chevrolet Corvette 65115878 65121102
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using the GM
Vehicle Inquiry System (GMVIS). Not all vehicles within the above breakpoints may
be involved.
For dealers with involved vehicles, a listing with involved vehicles containing the complete
vehicle identification number, customer name, and address information has been prepared and
will be provided through the applicable system listed below. Dealers will not have a report
available if they have no involved vehicles currently assigned.
Old 06-30-2006, 09:16 PM
HeapaShifter's Avatar
I'm a technician at a chevrolet dealership and it applies only to the LS2 and LS7 vette's in those vin breakpoints. All flywheels ordered off the internet should be good.
It's based on the rim step next to the locating pins.
bad flywheel with deep dish to the right of locating pin:
good flywheel with shallow dish to the right of locating pin:
The flywheel replacement part # we're given is :12571611
I can give a lot more pictures and information on this subject.
Old 06-30-2006, 11:53 PM
UAZ28SS's Avatar
Interesting, for sure. Do you HAVE to use the LS2 flywheel with the LS7 clutch, or can you use an aluminum one?
Old 07-01-2006, 10:32 PM
rickJames's Avatar
good news thanks for the info
Old 11-27-2006, 07:57 PM
minesfaster's Avatar
I hope i got the correct flywheel, my part number is 12571611 which you listed id the replacment part #.
Old 11-29-2006, 10:35 PM
JimMueller's Avatar
You can use an aluminum flywheel, but it needs to be designed as a LS2-flywheel replacement. I use Fidanza's but I'm not sure if there are other alternatives.
