Ive had it with my clutch!!!!! TIME TO REPLACE, HELP
cluth pedal sticks, cant speed shift...gears grind at higher RPMS...
i realize that there is a drill method..but im ready for a whole new better system....
what does everyone recommend? i want to be able to shift hard with no problems...i'd like an adj master cylinder so i can adjust the pedal and the shifter....and i want a bangin cluth that'll hold and that will engage/disengage with NO problems...money is not an issue...well you knwo what i mean
THANKS!
THANKS!
wrencher
Well I like the McLeod twin because it releases in a short amont of pedal travel. Most I've seen is w/in an inch or so of travel. The coil sprung pressure plate is the difference IMO, Vs the diaphram spring plate everyone else uses.
I like it for powershifting , works great in my case.
Just replace everything, do the drill mod on the line, & your set.
Originally Posted by Turo
Maybe its just me, but I think that a spec4 and Mcleod twin-disk are overkill for a bolt-ons car .
car will have about 425-40 RWHP N/A in about a month or two...soo i figure ill go bigger...
Thanks guys for the help...so even with new master cylinder and clutch i have to do the drill mod???
lemme know
Erik
Look into the Cartek clutch comes with a adjustable master and stands up to serious abuse. www.cartek.net
hey guys, thansk a lot for all in the info!
I really appreciate it....again I am looking for something (like the cartek) that I can adjust...i HATE the notchiness...i woudl like to be able to adjust that and the pedal
i am going to check out prices....compare....save..think....save...compare ...and so on...
it isnt the DD so...not worried bout it to much...but it needs to be the next mod..
THANKS
THANKS
