Installed the Pro 5.0
Old 08-19-2006, 06:56 PM
TORCHD 02 TA's Avatar
Default Installed the Pro 5.0
It arrived yesterday and i put in today. i also bought the 6" short stick too.
Here is my thoughts.
Pro 5.0 is a great shifter. had it in my 97 GT. Now for the handel. i put the 6 handel on, which is a straigth handel with no bends at all. SO put the car back together. After i was done i was looking at the stick, and at i noticed that it was not in the center.... So i went throught the gears. 1st gear looked like 3rd gear. 5th and reverest was sooooooooooooooooooo far over to the right, and it hit the side of the center consloe.. So i took the 6'' stick out, grabbed the pro 5.0 stick and cut 1 3/8'' off. compared the two stick and the 6" was about 1/4'' taller after i was done. put the pro 5.0 back on stick was right in the center i was a happy camper.
the main difference between the pro 5.0 and 6''SS is that the pro 5.o is angled to the driver! BIG DIFFERENCE!!!!
so any one deciding on buying the pro 5.0 and any of the ss (6" or 6.5") i would say NO and cut the pro 5.0 stick..
anyone have any other questions let me know...
Old 08-19-2006, 07:11 PM
SuperSport4life's Avatar
my lss sits in the middle and is angled to the driver it rocks
Old 08-19-2006, 07:31 PM
yup it sure does.. basically when you cut the pro 5.0 handel, it becomes the LSS..
Old 08-20-2006, 01:27 AM
bump for more responses
Old 08-20-2006, 02:34 AM
Revelation Z28's Avatar
my shifter angles towards me...
does it mean aftermarket or a stocker can do it?
Old 08-20-2006, 06:00 AM
z_speedfreak's Avatar
could anyone post me up a pick of how the shifter boot is supposed to be with the 5.0 installed? dont know if i did it right.. but yeah love the shifter, just miss my centerforce clutch
Old 08-20-2006, 09:35 AM
BLK02TA's Avatar
Trimmed Lous Short Stick =
Old 08-20-2006, 11:55 AM
HavATampa's Avatar
Which boot? There are 2.
Old 08-20-2006, 05:32 PM
1cleanbird's Avatar
hey, did u buy the shifter offline, if so where? Thanks.
Old 08-21-2006, 08:00 AM
i have a question and i think i may know the answer. When i shift slow going into 2nd gear if i do not use some muslce to get it in, it pops out of gear.. But if i shft slow and give it some muscle it goes in fine. Now i was thinking that it maybe how i set the stops?? Anyone else have this problem??
let me know, thanks
Old 08-21-2006, 09:53 AM
bastien's Avatar
same thing I did, cut 1 inch off the pro 5.0 shifter.. works great
Old 08-21-2006, 06:52 PM
HavATampa's Avatar
Wink
The stops only come into play once you get it in gear. They stop it from going farther than needed. Sounds like you just need to use more muscle and shift faster. I actually removed my stops from the shifter. Some use then some don't. Supposedly....the tranny has internal stops....supposedly.
let me know, thanks
Old 08-21-2006, 06:58 PM
02 Camaro SS's Avatar
I have the pro 5.0. I had a LSS stick on it and it was fine with the stock hurst **** but with my MBA shift **** it would hit the console in 2nd gear. I bought a stick that comes with the 5.0, cut it a bit, and put the shift **** on. I love the way it feels.
Old 08-21-2006, 07:46 PM
i told you i was sort of granny shifting.... so i guess i need to use more muscle in it.. i set mine jsut as a precaution.. and i too heard that the tranny has interrinternal stops.. i have been putting more muscle seems fine...
Old 08-22-2006, 01:25 AM
alky's Avatar
I got a 5.0 i'm going to install. Are you guys making a gasket or just using RTV to mount to the trans itself.
tia
Old 08-22-2006, 01:36 AM
andypz28's Avatar
gonna try to install mine tomorrow, cant wait.
got the 5.0 and lou's short stick as well, i saw on install university to use rtv sealant...
Old 08-22-2006, 04:13 AM
Shallow Bay's Avatar
Where are you guys cutting it and what are you using?
Old 08-22-2006, 12:40 PM
tia
i used BLACK RTV
put the shifter in a vise, used a good hacksaw and left about 8 threads on
Old 08-22-2006, 12:46 PM
Jakson's Avatar
I bought my Pro 5.0 from a guy on the board. He had a 1/2" spacer block made up to go between the 5.0 and the stick, so it puts the handle in the right spot. I have done that same thing going into 2nd gear a couple of times.
Quick Reply: Installed the Pro 5.0
