T-56 people where to build for 800rwhp/t
Old 08-31-2006, 07:21 PM
BOTTLEFEDLS1Z's Avatar
Default T-56 people
What all has to be done to the T-56 to handle over 800rwhp and torque. My car will see more street than strip. Let me know, please....
Old 08-31-2006, 07:25 PM
MonkeyBoneSS's Avatar
wrong spot for this one! best bet is to call t56rebuilds and they can tell you everything you need to know and do the work as well.
Old 08-31-2006, 07:32 PM
Actually I was hoping some of the guys running a turbo/6-speed combo would chime in and give me some insight..
Old 08-31-2006, 09:55 PM
FormulaFire's Avatar
Call t56rebuilds. They're awesome. But the rebuild will cost you a pretty penny. Unless you don't do the 5-6 cluster.
Old 09-01-2006, 10:23 AM
LS1TECH Sponsor
DrTurbo's Avatar
Try G-force as well. They do alot of the Viper tranmissions that are behind the 1500+hp monsters.
Old 09-01-2006, 10:43 AM
Senior Member
Country Boy's Avatar
My 6 speed was done by T56rebuilds..
Old 09-01-2006, 10:44 AM
White.Lightning's Avatar
GForce internals are the best out there yet very expensive. I do not know the exact "hp rating" of their transmission but as stated above, they handle some good power. If I had the money- I would be calling GForce.
Good luck
Andy
Old 09-01-2006, 11:00 AM
danimal95's Avatar
G-force Is The Only Way To Roll O N This One,myself And Intm8 Have These In Our Cars 1000+ Hp No Problems At All
Old 09-01-2006, 11:11 AM
Tiago's Avatar
stock for me at 950 rwhp
LS1TECH Sponsor
DrTurbo's Avatar
Yeah all the big 8 sec Viper's run G-force tranny's when they upgrade.
Old 09-01-2006, 01:45 PM
bboyferal's Avatar
Good point, because you're not alone and I've heard of alot of stock T-56's running ~750 rwhp... If you're gonna run street tires, is there really a need? On the track with slicks then I'd totally understand. I would like to know too, where the line is drawn.
Old 09-01-2006, 01:55 PM
Thanks guys for the replies. Looks like I'm gonna have to check out g force trannys......
Old 09-01-2006, 02:22 PM
stevieturbo's Avatar
Most of the rebuilds Ive seen advertised dont involve different gears, just shift related parts.
So aside from some form of cryo treatment on the gears that some offer, why would any of them be stronger than a stock T56 ??
Does this cryo treatment actually make much difference ??
I know when my time comes, I'll probably be going g-force.
Old 09-01-2006, 04:34 PM
qqwqeqwrqwqtq's Avatar
Both Danimal and I stripped the teeth off the input/countershaft gears while rolling into the gas in 3rd gear. This was on the street on radials.
No problems to date with the G-force transmissions, and fwiw the stock transmissions were holding up until we eclipsed 800rwtq.
Old 09-01-2006, 09:25 PM
Well I have already the steel 3-4 shift fork and a synchro rebuild kit form D@D performance.
I looked on Gforce's web site and really don't have any idea on what all I really need. I mean is the triple cone conversion a "must have" or what. I'll have to call Gforce and see what they say I guess.
What all does your T-56 have??
Old 09-02-2006, 01:07 AM
The PAT WS6's Avatar
synchros and shift fork rebuild kit. call up t56 rebuilds they are pretty good ive heard
Quick Reply: T-56 people where to build for 800rwhp/t
