At exactly what RWHP does the clutch start to slip?
like the title says, Im running a stock clutch right now in my 99 and have about 390 rwhp. Im just curious at what hp you start to lose hp to the wheels due to the clutch starting to slip under wot.
Kleeborp the Moderator™
It's actually the torque you need to be worried about (but a lot of people talk about HP ratings since HP is derived from torque).
Even on my car, my stock clutch showed signs of slipping with just bolt-ons at about 330-ish RWHP, 345-ish RWTQ, but that was from hard shifting on the street (but still on street tires).
I'd budget for a new clutch if you plan on driving it hard with that power...
Mine has a stock clutch on 84k, and slipped slighty on the these bolt ones.. i just finished my TNT F1 kit and did a 75 shot to test it out and clutch couldnt handle it... new clutch is siting next to me right now.
the ls7 clutch might me a great clutch for you.it holds decent power on street cars. i've heard it starts to fail at the strip however on slicks on hard launches with a pretty healthy motor but if you keep it on the street it should work out great.
The best I can see is not necessarily the cluth but who, and how it was installed. Seems to be a delicate procedure and if its not done right it will slip prematurely and if not broken-in properly will severly decrease the life. I see a lot of good and bad with clutches. Ive got the spec 3+ and it has worked for my application, but I dont take it to the track either just roll racin. Hope this helps and good luck.
my clutch went by-bye with my TDs/fipk/tune/and gs-d3s at 22k miles....i think the previous owner might have done some damage...maybe teaching his wifey to drive stick or something
