Clutch question.....for all H/C + N2O LS1's
Old 11-17-2006, 01:20 PM
Prey4Me's Avatar
Default Clutch question.....for all H/C + N2O LS1's
I will be on a 150 shot soon and just wondering all of your opinions on which clutches to look into and which to avoid. Also what slave and hydraulics are you all using? Any info,advice, or recomendations welcome! Thanks guys
Old 11-17-2006, 11:48 PM
Prey4Me's Avatar
No replies? Okay guys, anyone in between 500hp & 650hp let me know what clutch you are using.
Old 11-18-2006, 12:02 AM
Closed ex-Sponsor Account
autotrix's Avatar
Centerforce stage 2, and flush system to a DOT4 brake fluid.
Old 11-18-2006, 06:42 PM
brians98ss's Avatar
Textralia here.
Old 11-19-2006, 01:30 AM
Prey4Me's Avatar
How does it feel compared to stock? I drove a Z28 with a Centerforce dual friction, would it be close to that clutch? I will write down the DOT4 fluid, thanks for the info!
Old 11-19-2006, 01:35 AM
Prey4Me's Avatar
Originally Posted by brians98ss
Textralia here.
I have heard lots of good things about textralia. How does it feel while slamming gears and also just cruising around town? I'm starting to think spending a little more money the first time will be well worth it in the long run, I've heard a lot of horror stories about going with the cheaper clutches. Thanks for the info.
Old 11-21-2006, 02:56 AM
brians98ss's Avatar
Putting out almost 600 rwtq on the bottle and the clutch is holding fine. As far as the street, not too much different than stock. Pedal is a little stiffer than stock but not bad at all.
I did experience quite a bit of chatter during the first couple hundred miles or so but it is virtually non-existent now. Highly recommended.
Brian
Old 11-21-2006, 09:38 PM
GasTiresandOil's Avatar
Cartek on a cam only 150 shot in a goat
Old 11-22-2006, 07:26 AM
slow trap's Avatar
i had a spec 3 and had good luck other than when i slipped it alot in a parade and glazed it over or something.after about 500 miles and then some hard launches the chatter was almost completely gone.now i have a textralia ekoskel but haven't installed it yet.i've heard the tex oz700 is a great clutch .
Quick Reply: Clutch question.....for all H/C + N2O LS1's
