Will at T56 out of a 1993 fit my 1996?
Shirley Temple Drinker
I can take the bell housing off my tranny and use it on this one correct? What do you mean by front plate? Can you elaborate on the imputshaft and slave cyl throwout stuff?
'93 and '96 are both LT1s, so he won't need to change anything. It will bolt right up. I believe some of the '93s had different ratios from the 94+ T56s, zo6 and GTO gears I think.
It will work. The ratios were different................
Year Model/Optn 1st 2nd 3rd 4th 5th 6th Final
1993 Manual/M28 3.36 2.07 1.35 1.00 0.80 0.62 2.73 (GU2)
1993 Manual/M29 2.97 2.07 1.43 1.00 0.80 0.62 3.23 (GU4)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 2.73 (GU2)
1993 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 3.23 (GU5)
1994 Manual/MN6 2.66 1.78 1.30 1.00 0.74 0.50 3.42 (GU6)
1994 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 2.73 (GU2)
1994 Auto/MX0 3.06 1.63 1.00 0.70 -- -- 3.23 (GU5
Originally Posted by calhoon
Although the gearing will give more"grunt" as you say those boxes have a lower torque rating= 350 ft-lb vs 400 for the later ratios.
