Weird noise!!
Weird noise!!
Ok, this started about three weeks ago. It makes a spinning (dont know how else to describe it) and I can feel it in the shifter, but only when the car is cold and at about 1k rpm in second and third on deceleration. It engages in all gears without any problems, but I have noticed that it engages rather rough. I noticed that my clutch reservoir was low on fluid(about 2/3rds low). I refilled it and has not gone down yet. The clutch isnt slipping either. I was wondering if the slave was going bad or the throwout bearing. Im stummped. Anyone have any ideas?? Thanks
If you have the same problem that i did, which it sounds like by the way you describe it, i belive it was my pilot brearing, i replaced it and the noise was gone
I got the car in august and about mid september it started makin noise when i shifted gears and it also was kinda of hard to pull it in gear i would have to pull on it softly for a couple of seconds and then it would go in, i could even kinda fell it in the clucht, the noise sounded like something spinning like you said
