Clutch pedal gets soft...
Old 03-09-2007, 03:17 AM
BayAreaSS's Avatar
Default Clutch pedal gets soft...
Recently i have noticed when i row thru the gears my clutch pedal gets soft. It seems like its closer to the floor. It still shifts normal but just feels softer than usual.
Can you guys give me some opinions?
I have the ls6 clutch kit. It has about 9k on it.
Thanks.
Old 03-09-2007, 05:04 AM
Mystic 98 TA's Avatar
How many miles on the car?? Mine started feeling soft after I replaced the clutch/slave cyl, and it turned out I had a blown master cylinder. Noobie mistake, not replacing them both i guess. I had the new clutch and slave for about 3k miles, the master had about 90k on it at the time. Just one thought.
Old 03-09-2007, 09:14 AM
CARTEK Racing
WS6TransAm01's Avatar
I believe that problem is from the fluid if overheating. I would flush the master with new fluid. Should solve your problem.
Old 03-09-2007, 07:25 PM
BayAreaSS's Avatar
I did replace it when i put the new clutch in. I had everything replaced.
Thanks for the thought
Old 03-09-2007, 07:26 PM
BayAreaSS's Avatar
How do i do that, Is there a right up somewhere?
Can this damage anything if i make it overheat too many times?
Thanks.
Old 03-10-2007, 01:54 AM
BayAreaSS's Avatar
Bump...
Old 03-10-2007, 02:01 AM
greysteel_M6's Avatar
A soft clutch pedal at the top then firming up towards the floor means there's air in the system plain and simple. Try bleeding it.
Old 03-10-2007, 02:47 AM
BayAreaSS's Avatar
thats exactly what i think the problem is!
Old 03-10-2007, 08:52 PM
02silvaZ's Avatar
sounds like air to me
Quick Reply: Clutch pedal gets soft...
