Drill mod question...
For those that know about the drill mod; I will be getting a new master cylinder (as well as a new slave) both from the newer improved LS1 years, and I want to do the drill mod as well. Is this something I can drill into the new Master cylinder while it is out of the car? Any help is appreciated. Thanks.
Yes the master has to be out of the car to do it. You will need to disconect the line from the master. The end that goes to the master is the side with the restrictor in it.
Here's a write up on the drill mod.
Heres it the writeup from Install University:
http://www.installuniversity.com/ins...sity/index.htm
It should help you out. Note that they are installing a new adjustable MAster Cylinder as well, thats not necessary just to do the drill mod.
