Slave Cylinder Bleeder Thread
Originally Posted by skytower31
Could it be a 10mm x 1.0? I can't find any braided lines at 10mm x 1.5.
Are you trying to make a remote bleeder? You might want to check out this post I started here:
https://ls1tech.com/forums/showpost....86&postcount=1
That is everything you will need for a remote bleeder. You will need to use a -4AN braided line with adapters...
Originally Posted by AppleMac
No. It is 10mm x 1.5. (Same size as your pressure plate bolts if you want to check).
