Master Cylinder Problem Again.
Old 04-08-2007, 01:12 AM
WS686's Avatar
Question Master Cylinder Problem Again.
If anyone could lend me some advice that would be great. I have replaced my master cylinder a little over a year ago and it's going out again? Any suggestions on keeping another one from going bad or a different brand other than OEM ?? It's a 1999 LS1 TA Please let me know what you guys think I should do because it's annoying at the least and a waste of money.
Old 04-09-2007, 09:49 AM
Duffster's Avatar
bump for same info...
Old 04-09-2007, 12:52 PM
renxwar's Avatar
Not to get you guys excited for nothing.. but subscribing for info also.
Old 04-09-2007, 12:53 PM
brad8266's Avatar
What driveline mods do you have?
Old 04-09-2007, 12:57 PM
Kevin Doe's Avatar
did you verify that it was adjusted properly?
Old 04-09-2007, 12:58 PM
brad8266's Avatar
OEm masters are non-adjustable.
Old 04-10-2007, 09:24 PM
WS686's Avatar
I have done a brand new ZO6 slave and a Spec stage four clutch? Other than that its pretty much the same?
Old 04-10-2007, 09:50 PM
wrencher
wrencher's Avatar
I race my car, so I think it qualifies for extreme conditions lol.
But I regularly flush the fluid. I use it's color as an indicator as to when time to flush it.
If it starts to darken up, it's time to go. I usually flush at least twice a year.
Has worked great for me. No hydraulic issues anymore 4 years, & 2 clutches.
I also like to use a high quality DOT3 fluid, higher the boiling point the better.
Old 04-12-2007, 01:33 PM
dalejr8ls1's Avatar
I'd say get an adjustable master and adjust it out correctly. It is highly likely your problem is further down towards your slave too. A master shouldnt be going out like that, unless its a Mcleod or something where there are always problems.
I have a new RAM Adj. Master for sale, just PM me anyone is interested.
Old 04-12-2007, 04:22 PM
brad8266's Avatar
yep, check your fluid for its color, if its dark that means it has been heated up a enough to wear it out and possibly boil it. I wrap the braided line in heater hose to keep it from heating up.
