Air in slave cylinder??????????
My car is hibernating in the driveway right now, it will not go into gear with the engine running but will go into anyone when it is off, and I think its air in the line from the slave cylinder to the clutch. Am i going in the right direction or is there any suggestions on what might be the problem? Is there anyone who knows a website or where a right up will be on how to bleed the clutch with detailed instructions with pics. What do yall think about power bleeding, whats the best? Any info will help
I think my throw out bearing was goin out, do u think it could also be that?? when the car is on and i push in the clutch, and try to put it in gear the car starts to move forward slowly, but will not engauge into gear fully. the clutch pedal is very hard to push to the floor too??? Ill try to bleed it first!
Ok i blead the system today, and my clutch pedal feels a little better, but still wont go into gear, soo im thinkin it should be the master or slave! how do u get to the slave, do u have to pull the transmission?? Any Advice will help never had this problem!!
Plannin on it if I gotta go through all that ****! Im thinkin about ls7 clutch and ls2 flywheel (stock motor, but not for long!) is there a way to tell if the problem is commin from the master or the slave? HOW????
I ordered a stock master cyl. today, Im gonna do the drill mod, and make it adjustable, before I install it! I hope this is the problem, or else im gonna have to pull the tranny....damn!!!
Originally Posted by brad8266
If your old master cyl wasnt leaking fluid it more than likely is not your problem.
Gott apull the tranny to get the slave out. if you arer going to do all of that you might as well install a new clutch assy and slave.
If the slave isn't leaking fluid it's not bad. You'll know if it's leaking because it will be leaking out of the slit between the gear box and bellhousing. When you installed the master did you put it in bench bled with the reservoir attached and full?
I'm assuming by now you've got all new fluid in the system. If not, check the condition of the fluid, should be basically clear and free of contaminates. It's not your throwout.You'll hear noise when you engage the clutch if the throwout is bad. Either you have a bad hydraulic component, air or contaminates in the system, or your pressure plate isn't releasing. A very unlikely possibility is that the input shaft is binding up against the pilot bearing because of an alignment issue. This would cause the input shaft to turn when it shouldn't be.
I am finally gonnna get some time off to replace the clutch an flywheel, I got the fidanza aluminum flywheel in the mail the other day its f-in BADDDD, its so light! so tommorrow i will install every thing and pray that it works!
Ok finally i got the chance to install my new clutch, PP, an flywheel. The problem was deffinatly the clutch PP an flywheel, when i pulled the tranny the last time the PP teeth looked fine, but when i pulled it off last weekend half of them were in an the other half were out, ohh it was nasty! then i went ahead an removed the PP an clutch disk an it looked like my flywheel had herpes, Hotspots everywhere! lol I installed everything an it is running fine now!!!! much quicker revs, I like!!!!!! I had hell puttin the transmission back in though, I guess the disk was a little off. I broke a piece off of the bellhousing whle attempting to snug the bolts down while still manevering the tranny in place, does anyone out there have an extra one they want to sell or websites i can order from, I cannot find these things!?!?!
