spec 3 or ram?
i'd go with the ram from my spec experience,but it was the regular 3 instead of the better one so it is probably a toss up between the the 3i and power grip.both should hold up well.
Mean, what kind of power are you making now...what is your goal for power in the future? I ask because this will greatly impact your clutch need. Let me know and I will happily provide info on the best options for you. Thanks,
A stage 3 would be fine for your application...in fact you would actually be over clutching the car with this unit but if you plan to add further modifications I say go for it. It is more on and off than a full faced disc would be but tons of folks swear by them. Let me know if you have any further questions. Thanks,
Spec 3 Welded To The Fly Wheel Spec Says Hammer It Off Reinstall And Your Good To Go They Have Never Seen It Before Have Pics They Do To If You Want To See Call Spec Ask For Justin 4 Sale Cheap
As mentioned above Stage 3 would work perfectly fine for you. As a side note...does anyone hear an echo (April)...chirp, chirp, chirp...(Just kidding of course as I posted before you are welcome to contact me directly to discuss any issue that you may have). Thanks,
i now have alot more respect for my spec 3. have contacted someone else at spec, will send back clutch so they can take a better look at it. clutch has approx 2000 miles on it. sounds like spec wants to do the right thing. first guy must have been having bad day
