t56 not slideing in all the way
Old 04-26-2007, 12:57 AM
CheeseNR7's Avatar
Default t56 not slideing in all the way
i am haveing a problem installing the transmission ... it does not want to slide
in all the way it slides through both clutch disks (spec dual) and just stops about an inch short of being in all the way ... pilot bearing is brand new and i am useing a mcleoud bell houseing ... any advice?????????
Old 04-26-2007, 04:41 AM
squealingtires's Avatar
Try seperating the bell-housing from the transmission. Put the bell housing on the block first and get it bolted down then put the rest transmission on. When done in this manner it becomes much less frusterating. This is less awkward too. good luck
Old 04-26-2007, 07:30 AM
CheeseNR7's Avatar
that is how i am doing it .... with the bigger mcleoud bell houseing its almost im possible to do it as one .....
Old 04-26-2007, 08:02 AM
wrencher
wrencher's Avatar
I have had a few twin disc clutch sets that I had to align the disc's with an actual input shaft. The plastic tool was not good enough.
Then they slid right in.
Old 04-26-2007, 08:19 AM
SladeX's Avatar
crack the bleeder on the slave.
Old 04-26-2007, 11:37 AM
gun5l1ng3r's Avatar
Keep maneuvering it, it took me an hour to get it aligned properly...
Old 04-26-2007, 12:01 PM
Jon5212's Avatar
Get 4 longer bolts for the transmission itself, put 2 in on each side that are easily accessible and tighten those down to pull the tranny in the rest of the way, then start putting in the actual transmission bolts, will save you a lot of heartache.
Old 04-26-2007, 03:06 PM
3.4camaro's Avatar
thats a good way to ruin the spline and the clutch friction disks. leave that method to the auto guys.
Old 04-26-2007, 03:19 PM
Mike44138's Avatar
Not to mention potentially crack the case on the gear box. You're right, you have to be careful if you do it that way. I usually use 4 longer bolts with the heads cut off as an alignment tool, crack the bleeder on the slave, and when I'm confident that the input is properly engaging the disc and the gap is reasonably small GENTLY and evenly use the stock bolts to pull it all together.
Old 04-30-2007, 10:57 PM
CheeseNR7's Avatar
thanks for all the imput .... i actully got fed up and took it to a tranny shop and there haveing the same problem i will pass the advice on to them ... thanks again
Old 05-01-2007, 07:40 AM
4Birdman's Avatar
Rubber mallet!
Quick Reply: t56 not slideing in all the way
