Textralia 0Z700 engagement before/after break in
For those using this clutch, did yours grab like one inch off the floor initially? Is this normal? I imagine as the disc wears the high spots down the engagement point should move back up, but it seems a little low.
Any thoughts?
Any thoughts?
Originally Posted by vettenuts
Bleed it some more, how did you bleed it?
Clutch engagement should be very similar to the stock pedal feel. The two issues I most often see with poor pedal engagment is air in the hydraulics, or a pressure plate bolt that has backed out.
If you continue to have issues PLEASE contact us @ admin@textralia.com.au with a number to get back to you at.
Let me be clear to anyone else. If anyone using our product has any sort of issue, we're here to help you guys with any tech support issues you have. Please get in touch with us.
