LS7 Clutch
LS7 Clutch
I acquired a complete T-56 setup to convert my A4. I was told the LS7 clutch, pressure plate/LS7 flywheel all have around 5000 miles on them. The clutch looks to be in really good shape except the inner springs. 2 of the 4 inner springs (the yellow springs) rattle pretty good. They seem really loose inside the bigger outer springs. I have never dealt with dual spring clutches and have no idea if this is normal or not. I would like to use this clutch but will buy new if I have to. Feedback please.
Originally Posted by Mike94ZLT1
The LS6 clutch and pressure plate are not compatible with the LS7 flywheel. Post some pics so we can see what you have.
My bad, that is a typo. I have the title right. I def. have an LS7 clutch, pressure plate and flywheel. I just need to know about the springs in the clutch.
bump i saw this to and is a little yellow spring inside another spring and its not hooked up to anything! The little spring is just in there loose moving around and not hooked up to anything!
Anyone know why this is? Mine just arrived from SDPC today, and when I picked up the disc, I was quite surprised by the rattle of one pair of inner springs!
