is this bad??? someone read
wrencher
Get a bendable magnet & get it back out of there.
otherwise your pulling the trans back to get it. I would go the magnet route to retrieve it.
I would not suggest leaving it in there. The aluminum motor & trans wouldn't have a chance against that socket flying around in there.
10 Second Moderator
I'd try a good magnet attached to a string. Go in thrugh the slave line hole. Or if you are real brave just drill a hole in the bottom of the bell and pull it out thrugh the hole. I had a one inch hole in the first T-56 bellhousing I ever had in my car, never knew why the hole was there but it was never a problem. Good luck
can someone please help me i still cannot get it out and i drove the car to midas to see if they would try and get it out but couldnt they said 500 dollars to seperate the trans from the engine and get it out and i said **** no...i really am running out of ideas what could happen if i leave it in? i was wondering if i can go through the starter?
i finally got it out thanks alot the starter helped so much it also made a nice hole in my bellhousing i guess driving it home from the mechanic im never letting other people work on my car but thanks for the help
