6th gear not engaging ???
Old 06-18-2007, 01:53 PM
GTBAF333's Avatar
Default 6th gear not engaging ???
My 6th gear will not engage and I am wondering if it sounds like it might an easy repair that I can do myself or is it pretty complicated. I'm very mechanical, but never really messed with transmission internals. Every other gear is fine but 6th gear will not engage. I can pull the shifter into where it is supposed to be but all I can feel is like teeth ratcheting trying to engage. Any insight would be appreciated. Thanks
GREG
Old 06-18-2007, 02:00 PM
ONEBADASSWS6's Avatar
GREG
Sounds like its time for a transmission rebuild. Thats not something you can fix yourself unless you have intricate knowledge of the T56 and a gear puller, as well as ither special tools.
Old 06-18-2007, 03:07 PM
GTBAF333's Avatar
So who do people recommend for quality rebuilds ? I was thinking about buying a sixspeedinc rebuild kit and having a local shop build it up.
GREG
Old 06-19-2007, 08:01 PM
Black_98Z's Avatar
I have the exact same problem.
Old 06-21-2007, 01:52 PM
GTBAF333's Avatar
bump,
Old 06-21-2007, 03:56 PM
Taco's Avatar
I had the exact problem in 5th and 6th. Amber @ sixspeedsinc.com says I have a "bent 5-6 shift rail" that caused it.
Don't know if that would be the same thing, but it is likely.
I STRONGLY recommend six speeds inc for your rebuild.
(Amber, if you read this... feel free to correct me if I mis-quoted you)
Quick Reply: 6th gear not engaging ???
