Replacing clutch very VERY soon..few ?'s
Old 07-02-2007, 11:36 PM
firehawk618's Avatar
Default Replacing clutch very VERY soon..few ?'s
My clutch is on it's way out. Can't grab 2nd 1/2 the time without it slipping till I lift off the throttle a little...anyhow it's getting replaced....
I'm a mechanic and have done literally hundereds of clutches in all kinds of cars.
On my 00 T/A is there any special tricks, hidden bolts or whatever that I may encounter? Or is this one simply as straight forward as it appears.
How many hours should a experianced mechanic expect to take doing this off jackstands?
Thanks
Old 07-03-2007, 07:40 AM
Specialized's Avatar
Id say about 3.5-4.5 hours as long as you have a tranny jack. Thats being conservative.
I can take out my tranny in.. a little under 2 hours by myself.
Old 07-03-2007, 08:26 AM
A-Dub's Avatar
Nothing really tricky about it, make sure you get all the trans/bellhousing bolts out.
If you plan on replacing any of the hydaulics, add in a fair amount of time for bleeding.
Old 07-03-2007, 09:58 AM
99ssleeper's Avatar
getting the trans out and the clutch in doesnt take that long...its the exhaust, tq arm, and hydraulics that take time. the master cyl is a bitch to get out if youre replacing it...it has to be removed from under the brake booster.
i didnt unbolt the torque arm from the rearend so i unbolted the clamshell on the front and it was tough to get back together.
i disassembled mine before the parts arrived, but i'd say it chould be done in 1 day on stands if you dont mess around with stuff like i did.
read up on the install at www.installuniversity.com
Old 07-03-2007, 06:40 PM
Cool. Mainly conserned with tricky bolts and such. Sounds pretty straightforward.
I prefer to remove items if I even remotely think they're going to interfere. Seems to save alot of time and frustration.
Old 07-06-2007, 01:14 PM
Gary Z's Avatar
I am amazed by how fast professional mechanics work. Nevertheless, on jackstands, replacing an f-body clutch the first time, plan to put in a long day. The service manual says to remove the trans and bellhousing together. That’s bad advice - remove the trans from the bellhousing.
Old 07-06-2007, 01:24 PM
daryl2cb@yahoo.com's Avatar
well among other things you need a clutch line disconnect tool, also word of advise, from someone who has toasted 2 clutches in a car that has only 28,000 miles on it. get a new slave. and make sure it is the 01-02 updated version do not install a new clutch with out doing this, the new clutch will cause your old unit to fail really fast, also a remote bleeder is 80 bucks well spent. flush the whole system as well, dot 4 is best. 3 hours for a tranny removal, 4-5 to install, the torque arm is going to be the hardest part of the install.
Old 07-06-2007, 01:44 PM
99ssleeper's Avatar
you dont need a clutch line disconnect tool. take 2 small screwdrivers and push the white ring on both sides until it is all the way into the slave cyl fitting. the line will pull right out. i did mine that way with no problems at all.
Old 07-06-2007, 02:32 PM
Sounds like the setup newer rangers have.
Quick Reply: Replacing clutch very VERY soon..few ?'s
