could this be clutch slipping
when i get at high rpms at about 90mph+ it is like the car gives out like slipping. my rev limiter is set at 6500 so i know it aint hitting the rev limiter.
I have a luk pro gold clutch. so is that slippage
ok brand new 12 bolt 4:10 gears and my coolant light is on but the coolant is full and the pedal feels great and the clutch have about 3000 miles on it %on pressure i dont know what are you talking about, and now i have a chatter sound coming from the transmission and when i turn it sounds like its knocking or clucking.
Originally Posted by Travose21
will that affect my clutch. coolant temp
I will be on the gas 100% down. going down the quarter and as soon as i hit 3rd and i am on the pedal 100% we it get to about 5800 rpms it just start slipping like the car will rev up and hit the rev limiter. before i buy a brand new clutch i wanna make sure that it what it is. and also it makes a cluttering sound when i am in neatural and off the clutch but when i press the clutch it goes away someone please help me
well, I would say in 3rd gear there would be enough load on the engine. It does sound like the clutch may be at fault but I definately wouldn't blame it yet. How old is the slave cylinder? 98's usually have issues with failure and the newer slave is a must for a new clutch. I'm still thinking what would make the noise or slippage other than worn parts.
about 4 months is got a new 02 slave, 02 master, a luk pro gold clutch(dont know why i went with that but) I spent 2800 with parts and labor. if someone wants can they call me at 504-228-4017
Sounds like your clutch is slipping a bit, do this... stick it in 5th gear at like 35-40 mph and stand in the gas and see what happens. If its not slipping it should hold and RPMS should come up REALLY slow... if it slips your RPM's should jump fast.
