Man am i Fkd
Man am i Fkd
ok here we go for the last 2 days i been trying to blled my clutch after pedal went to floor. so i search and read the threads on how to. so today i purched a mity vac so im all bucked up like yes finally its goin to be over. ok i got the socket stuck on the valve so i gave up on trying to get it free after sometime so i gets a IDEA just losten it all the way up and take it off once i remove valve... well i i did that and the it fell in a whole so now i think the socket and valve stuck to gether than fell in there YRFGDFHGHPIOJHCXRYTGUHFGBIYGHXFFUKLIY>HJGVCHTEGHTD GHFGHBUIYGKJDH thats just somethings i said lol ok my point how F'd up am i is there hope?
Sure you're fkd, but there is always a sliver lining..... You just have to remove the transmission, buy the remote bleeder from a sponsor on here, install it, reinstall the trans, bleed the system, and you're back on the road!
1 Post
DUDE UR FU*CKED LOL dammmmm now r gonna hav to drop ur tranny or looosen the tranny bolts enough to pull it back enough till the thing falls out!! man it would reallyy suck to be u right now, if u need any help or got questions just pm me good luck bro
You're not as screwed as you think. All you have to do is loosen the tranny bolts holding it to the bellhousing, pull the tranny back a bit, and use a pen magnet to fish out the socket/bleeder valve. You probably won't have to completely remove the tranny, just loosen it a little. Then, just screw the bleeder valve back in the slave cylinder and bleed the system for air. You are using an 11mm or 7/16" socket, right?
man i went to bed last night with a head ache. you right at least its a chevy. i think ill just take a break from it for the weekend i have a truck to paint.Thankx for the advice ill try it... i was so pissed i could have kicked my dog, slap my kids, and pissed on a cop car last night lol!!!
ok i took a few days off. after talkin and reading i desided to cut a little whole in the floor and fish it out through the same whole it feel in. ill up date later with results
Man, I would never cut a hole in my floor.
I changed my slave cylinder in less than 4 hours, start to finish. This required removing and reinstalling the transmission.
Of course, I'm a tool junkie and I have the experience.
Cutting the floor of the car just makes the hair crawl on my neck......
bro the same thing happened to me i thought it was the end of the world but it really isnt that bad ....you have to get some string and a small pen magnet break the tip off and bend it so it stays on the string and do some fishing it takes a little while but when u pull it out and that little pos socket is on their its the greatest feeling haha and then u throw it against the wall and never bleed the clutch again without a mityvac
Your car is done for, I will tak eit off your hands for a case of beer! Seriously, it could be worse. If the socket is still stuck to the bleeder screw, you may be able to fish it out, although it is going to be a nightmare getting it back on the slave without cross threading it. Good luck!
Originally Posted by renxwar
FYI, bleeding with the mityvac sometimes causes the seals in the master to blow out. Since your going in there anyway, just get the remote bleeder.
ok i tryied might vac but i have no clutch at all now.i opened valve and pumped vac ,and poured fluid in like 3 times i fulled up fluid catcher. was that the correct way or i missed somethin
I FEEL LIKE A DAMN ***. i was under the car puttin the mighty vac on the valve i just read the sticky and seen the pic i need to put in the container DAMN DAMN DAMN 2 weeks of not riding ****! going do it now lol
Good luck, man. Fun only goes so far when faced with all the problems and the fact that our cars aren't as good in the quarter on the strip. If I weren't adicted to the M6, I'd get an auto.
i have a new master on the way i went with ram. i got some clutch but not enough to go in gear so i think the master is bad its like its not engaging enough to let me in gear. there cant be any air in there now i done did it every way it can be done.
