LS7---best buy???
LS7---best buy???
two questions.....who sells the ls7 clutch kit the cheapest?....the only place i found that has it is speed inc and they charge an extra 200 for the flywheel. and is the lst clutch kit the best bang for the buck right now?....i have a h/c ws.6.......
LS1TECH & Trucks Sponsor
LS7 Clutch Kits @ SDPC!
On that page we've got the clutch kits as well as any of the other parts you might need/want while doing the job. The kit is $399 and we keep them in stock!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Ordered mine Monday! Havent got it yet hopefully in a day or so! They threw throwout bearin,pilot bearin, and bolt kit in for free, but the order was still 460 something for the clutch and all
I'm considering ordering one from SDPC soon too, is there anything special that you need for installing it on a 1998? I just want a solid list of what to buy so I don't end up forgetting anything. My list looks like this so far:
LS7 kit from SDPC
Pilot Bearing
Bolt kit (maybe)
Slave Cylinder
Drill Mod
New Fluid
Am I on the right track? Anything missing?
Thanks
LS7 kit from SDPC
Pilot Bearing
Bolt kit (maybe)
Slave Cylinder
Drill Mod
New Fluid
Thanks
Don't forget an alignment tool if you don't have one already! For under $7, you can save yourself ALOT of headache and frustration.
__________________
Yes, they're listed on the page in the link in post #2 above as well!!
__________________
+1 for SDPC. Got my LS7 clutch/pressure plate/LS2 flywheel kit, pilot bearing, new master and slave cylinder from them. I wish I had gotten the bolt kit and alignment tool, had to go out and get those seperately. Shipped pretty quickly, too.
Location: Your girl's back door giving her the long stroke while you're at work
If your car is close to stock then the LS6 will be okay. But you are better off getting the LS7 because it will hold more power and it's cheaper
Finally got it in....Thanks SDParts!!!...this clutch is awesome...
here's proof: http://www.fquick.com/videos/Heads_C...m_Burnout/3327
