anyone with a ls7 clutch using a lightweight flywheel ??
I was wondering if anyone using a ls7 clutch was using an afermarket flywheel ? I know everyone uses a ls2 flywheel since it comes with the kit but I was wanting to freee up some ponies . Any help would be appreciated .
Just some info I've came across. I've been doing some searching on this subject lately. I want to get the ls7 clutch but don't want the extra weight that the kit adds. At this time the only aftermarket flywheel I can find is the firdanza there is no billet steel flywheel that I can find anywere execpt for spec which has to be run with there clutches. A billet steel would be ideal as it would keep the whole setup just a few pounds over stock. The ls7 with firdanza will be lighter than stock which is't necassarly a bad thing but many say its not good for drag racing and the rpms drop faster inbetween shifts. You can pick up a fidanza on ebay for $350 to your door but even at that price your looking at about $600 for flyweel and clutch assembly, so about $200 more than the just running the stock ls2.
Stock ls1 flywheel-24lbs
Slp billet ls1-16lbs
Stock LS1 (2004 GTO) - 49lbs
Stock LS7 (2006 Z06) - 57lbs
LS7 flywheel weighs 26.5 Lbs
Firdanza ls7-13lbs
Ls7 with firdanza-44lbs
Firdanza ls7-13lbs
Originally Posted by Black02SLPSS
Would an SLP billet steel flywheel work with the LS7 clutch disk and pressure plate?
appreciate all the feedback on this . this is about all i could come up with myself and there appears to be only one alternative for now to running a stock ls2/ls7 flywheel .
maybe someone that makes these will take note as there are many light flywheels for a reasonable price made to work wih a ls1 though only one for the new generation .
Originally Posted by 68birdls1
Fidanza does make an aluminum flywheel for the ls2, but it costs almost $400. I don't know if anything else is being produced right meow
How do I know? well, I've got one sitting in my room right now along with a LS7 clutch. My friend just installed a LS7 clutch and Fidanza fw in a C5 Vette just the other day. He said it felt great!
Fidanza makes an aluminum flywheel for the LS7 clutch
its a ls2 flywheel, the ls1 flywheel will not work with the ls7 cltch, only the ls2 flywheel
if you dont drag race a lot, go with the ls2 aluminum flywheel. if you do , its gonna be really hard to launch with it.
There's a seller on ebay that will accept a "Best Offer" of $335 shipped for the Fidanza LW flywheel that you need. I just picked one up myself and I believe he has two more available. You can also get just the LS7 PP and friction disk from Scoggin Dickey's for ~$250.
LS1TECH & Trucks Sponsor
Fidanza is the only alternative I've found so far. We are trying to keep them in stock, but they are moving quickly!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Why even get an LS7 (aside from cheap price)? They have high rev shifting issues. There are tons of better options around, esp if you're going to spend more money on a lighter flywheel. I had a Monster LT1-S (lightweight) in my TA. Well 49lbs isn't "super light" and what the stock one weighed but it was smaller. Getting a Centerforce lightweight for my new car (44lbs).
The following users liked this post:
Coy (01-31-2022)
