MN12 in a 98 Firebird
Originally Posted by _JB_
Not without a huge conversion process. Two totally different transmissions.
All you really have to do is swap out the shifter cup from your T56 into the M12 and it is a direct bolt in.
Galen
Originally Posted by Galen
Damn...now you tell me! I guess that since I just bolted mine up and have been driving it like that for over 10,000 miles I need to look into the "conversion process" to see what I had to have done wrong.
Galen
Galen
Galen
Galen
i guess you did lol serious is it any better?
I thought a MN12 tranny is out of a C5 Z06?
Tough Mudder
I've got one too. I created a chart that shows the equivalent gear ratios that you would have if you have 3.42 or 4.10 gears.
https://ls1tech.com/forums/manual-transmission/776536-comparison-f-body-gto-t-56-a.html
You can get one from me for $25 plus shipping. The GTO sits the shifter farther back and the GTO shifter is the only one you can use. With an F-Body shifter assembly you have more choice and all of my trans customers that have RX-7's use the F-Body shifters.
Thanks,
Amber
Thanks,
Amber
The M12 (there's no 'N" in it's RPO) is a T56. It simply has different ratios and other improvements than the version found in the F-Body. It's price should be comparable to that of any other "non-built" T56.
How much does an M12 cost?
What are the advantages of having a M12 rather than a t-56?
A GTO trans is $2250 built compaired to an FB at $1950. Due to the blocker rings being triple cone in the GTO that is what drives the price up. As for putting one in, all you have to change is the shifter assembly over to the FB and it is a direct bolt in. The GTO is a 2.97 1st gear which alot of the road racers prefer. Most of the time the GTO will shift better and be smoother.
The only issue is that the GTO is alot harder to get since they stopped production. It normally takes me 4-6 weeks on average to gather all of the parts for one. I just got a few mainshafts yesterday. Since the gears are the same as the Z06 that tends not to be an issue most of the time.
Thanks,
Amber
Thanks,
Amber
Thanks,
Amber
Thanks,
Amber
Driving the car you can physically feel the difference inthe transmissions, the m12 there is no dobt about when it is in gear, even with a stock shifter. The tension is more firm and 1-3 gears do react a lot better as far as the power band is concerned ( all of these are just observations i have made sicne my swap) i personally preffer the feel of the m12 as opposed to my old t56.
