Whats needed: LS1 T-56 behind BBC??
I know, I've used the search button, but can't find very specific answers as to what is actually needed. I've got a 402 BBC that I'll be dropping in my '68 Malibu, and I also have the stock T-56 that came out of Dad's Firehawk several years ago and got to wondering. What all is needed to get the t-56 to work? I read that a different bellhousing is needed. The stock bellhousing is with the tranny as well as the throw out bearing assembly. If I got the hydraulics off of a wrecked 6-speed car is there a way to use this, or would it be better to get a different bellhousing that uses the old fork kind of style? The car is NOT an original manual car, so a pedal will be added too...lol. I know this sounds like alot of work, but the 6 speed sure would be fun and allow for better fuel mileage also. Thanks.
Chris
Chris
You'd use just a regular GM 26 spline clutch kit from a 1969 Camaro with a 4 spd Muncie in it . Its a lot simplier than screwing with the hydraulic system on the newer F body cars . As you can see , more people have issues with the crap than success with it .
I did a conversion set up a while back using this adapter on a 69 Camaro with a 396 and it kicked *** ........
The conversion we do use a LS1 trans with LS1 bellhousing and adapter from Mcleod. We average about 3 of these per week and everyone likes the hydraulic method better than the fork. We have seen dozens of the forks break over the last few years as well as the slaves so it will just about the same.
Call me if you need specific help on the conversion. I have a whole list of the items you will need as well as the cross member information.
Amber
Amber
WOW!!! Thanks for the info!! Six speeds inc. I'll be giving you a call here real soon. I figured there had to be several people that's done this before. Awesome, I'm glad this is doable, should be lots of fun!!
Chris
Chris
