viper T56
Old 11-24-2007, 01:50 PM
LedZeppelin725's Avatar
Default viper T56
ok guys, i can get a T56 out of a srt10 truck and i was wondering what needed to be done to it to work in my car!! please guys i need some help i can get this trans pretty cheap!
Old 11-24-2007, 01:52 PM
dochall22's Avatar
check the stickys for the a4-m6 swap
https://ls1tech.com/forums/manual-transmission/200480-m6-a4-a4-m6-conversion-info-requested.html
Old 11-24-2007, 01:56 PM
thesource's Avatar
The Viper unit and the Gm stuff does not easily interchange .
Old 11-24-2007, 01:59 PM
im talking about what would have to be done to the trans cause i know that LT1 and LS1 T56's are different
Old 11-24-2007, 04:24 PM
thesource's Avatar
When people say they have a Viper unit in there F-body they mean its an F body unit built to Viper specs . Basically its a F body T56 with updated syncros , steel 3/4 shift fork and a Viper mainshaft . This requires the tailhousing to be bored out to accept a larger tailhousing bushing and rear seal . The other issue is the speedo gear as well . Its not a simply swap and most shops cannot do the required modifications to make it work . I have done a few but they are expensive and not needed unless the person is making a whole lot of power .
Old 11-25-2007, 02:34 PM
thanks guys for the input, so do you think it would be more beneficial to just get a LS1 T56?
Old 11-25-2007, 04:01 PM
thesource's Avatar
With out a doubt ....
