Throwout bearing question
When My foot is off the clutch there is chatter, when I push the clutch in it goes away. I am guessing it is the throwout bearing. I have a Textralia clutch and you cannot buy Textralia parts you have to buy the whole clutch assembly. So My question is will the McLeod throwout bearing work on this assembly? http://www.byunspeed.com/product_inf...915bde4f46b601
Thanks - Jeremiah
Thanks - Jeremiah
Isn't the TOB integral with the slave cylinder? I can't see needing a textralia specific part as long as the dimensions of the TOB you use are of the same as the one you have now.
It is serviced with the slave cylinder, unless you bought something aftermarket. I believe the textralia is designed to work with factory hydraulic's and bolt in without modification. You may be able to buy a TOB at an auto parts store, but with GM its only available with the slave cylinder.
You don't need to buy a complete clutch assembly. The slave and the throwout bearing from GM are a complete unit and thats all ya need if your bearing is fubar. The Tex clutch assemblies work with stock configuration. By a GM "f" body slave assembly and you are gold. You can also use the Mcleod bearing like you asked but I would reccomend replacing the slave also while in there anyway. Also when you are in there replace your pilot bearing. And before you ask, yes you can use the stock GM replacement pilot bearing if you want. HTH
