Help!!! Gto M6 To Ls1 .....
Old 12-31-2007, 09:44 AM
TRANSAM75's Avatar
Default Help!!! Gto M6 To Ls1 .....
My father is trying to mate a 2004 gto m6 to a generic LS1 that I got from G.M. that they were clearancing. The problem is that when putting the two together the input splines are hitting the pilot bearing and the bellhousing is still 1/2 inch from the block. And the pilot bearing is the one that came with the engine and is seated all the way in. The engine is supposibly a 2004 GTO block with a CTS pan that was used for industrial purpasses. Do we need a different bellhousing? Are some bellhousings deeper? Any help would be appretiated.
Old 12-31-2007, 09:48 AM
TRANSAM75's Avatar
I did notice that GTO and F-body bellhousings are different part numbers in my cataloge.(i work in parts at dealer)
Old 12-31-2007, 09:59 AM
99FormulaM6's Avatar
why are you doing this?
Old 12-31-2007, 10:11 AM
TRANSAM75's Avatar
WHAT KIND OF QUESTION IS THAT?
IT IS ALL GOING IN A 65 NOVA. I GOT THE BRAND NEW ENGINE FOR $2200 AND HE PICKED UP A USED M6 WITH 12,XXX MILES ON IT.
Old 12-31-2007, 11:52 AM
ls1 joe's Avatar
The GTO Bellhousing and the 98-02 FBody are the same. What pilot bearing are you trying to use?
Amber
Old 12-31-2007, 12:29 PM
TRANSAM75's Avatar
Amber
IT WAS NOT CHANGED, IT IS THE ONE THAT CAME WITH THE ENGINE. IT IS A ROLLER BEARING. AND IT APPEARS TO BE SEATED ALL THE WAY IN. THE SPLINES ON THE INPUT SHAFT HIT THE BEARING BEFORE THE BELLHOUSING TOUCHES THE BLOCK? ANY IDEAS? ARE THERE DIFFERENT BEARINGS? THIS ENGINE IS KIND OF A BASTARD MOTOR (BUNCH OF DIFFERENT PARTS) IT WAS USED IN FORKLIFTS ACCORDING TO G.M. TECHS.
Old 12-31-2007, 12:32 PM
1cleanbird's Avatar
no need to yell lol.
Old 12-31-2007, 12:37 PM
ls1 joe's Avatar
Sounds to me like the wrong pilot bearing is being used. They have made several. You would need to use one from a 98-02 LS1 Camaro. Also you don't want to yell when all people are trying to do is help.
Amber
Old 12-31-2007, 12:57 PM
TRANSAM75's Avatar
Not yelling, I work in parts at a dealer answering phones and all our work is done in caps. It is a pain when i have to switch back and forth inbetween calls. sorry. By the time i have typed all of this i have answered 6 calls. Thank you everyone for your answers.
Old 12-31-2007, 01:17 PM
whyte95ZRida's Avatar
HE BEAT ME TO THE REASON WHY ITS IN ALL CAPS......LOL We do the same thing here.
Try finding a new pilot bearing and see what happens. Just do not use the pilot bearing tool pushes on the backside of the crank! There has been a couple of people I know *cough (including me) cough* that pushed the freeze plug into the oil pan.
Bearing p/n 14061685
Old 12-31-2007, 01:31 PM
TRANSAM75's Avatar
Amber
Are you positive there is no depth difference in the two bellhousings?
My dad swears that the input shaft cant go any further into the crank.
Old 12-31-2007, 01:39 PM
ls1 joe's Avatar
Yes, because we sell gto trans to f-body customer all the time. A gto trans can go in a f-body and a f-body trans can go in a gto. There are two steps in the crank one is for the sealed roller bearing and one is for a needle style roller bearing. The one that is for the sealed roller bearing in the larger outter step, and the one that is for the normal f-body is in the inner step of the crank shaft, which set about 1/2 inch deeper in the end of the crank.
Old 12-31-2007, 01:41 PM
ls1 joe's Avatar
If the pilot bering is flush with the crank then it is the wrong one. You must use the small pilot bearing for an f-body.
The parts book shows two different #'s
F-body=12453263 V-body(GTO)=92142856
They should have the same geometry even if they have different #'s. I don't know why its like that but I'd listen to Amber and try a new pilot bearing. They know what they are talking about.
Old 12-31-2007, 01:44 PM
ls1 joe's Avatar
I know that the p/n is different and they look different on the outside but the dimensions are the same.
Old 12-31-2007, 02:10 PM
TRANSAM75's Avatar
Thank you,thank you, thank you!!! That was it!!! His bearing was flush with the end of the crank!!!!
Old 12-31-2007, 02:19 PM
TRANSAM75's Avatar
That is the best answer to a question i have ever gotten on this site!!!!!! 2 thumbs up!!!
Old 01-03-2008, 04:45 PM
jmd
jmd's Avatar
I could tell right away that he wasn't going into the pilot area correctly but I figured the clutch wasn't aligned. Great post diagnosis Amber.
Old 01-04-2008, 10:21 AM
TRANSAM75's Avatar
The clutch wasn't installed yet. The engine had a large 2 inch bearing that was flush with the end of the crank. He needed the smaller bearing that fit in to the smaller center hole.
Quick Reply: Help!!! Gto M6 To Ls1 .....
