Spec 5 street, search down
Old 02-14-2008, 10:28 AM
Ryanmgaspard's Avatar
Default Spec 5 street, search down
Is the spec 5 clutch system overkill for a street car with little mods? The engagement might be harsh.
Old 02-14-2008, 10:32 AM
ls1 joe's Avatar
Yes. The vipers use to use a SPEC 5 when they made 1200rwhp. For anything less than 500rwhp a spec stage 3 would be the best option. Great street ability while good drag strip if you want it. A spec 5 will drive horribly on the street with low mods.
Thanks,
Amber
Old 02-14-2008, 10:34 AM
HeavyWeight's Avatar
The SPEC 5 Grabs Very hard, but I like mine and I DD it so I think it is what you can tolerate. Plus I dont have to worry about any slippage.
Old 02-14-2008, 10:44 AM
Grabs hard as in whiplash to the neck when you shift? Enlighten me
Old 02-14-2008, 10:47 AM
ss1
ss1's Avatar
There are no springs in the disc, plus its an iron disc. When you let the clutch out it can have a tendency to be jerky or chirp the tires. Its overkill for a car with few mods and if you try to drive it like a regular clutch it won't last more than a few thousand miles.
Old 02-14-2008, 11:02 AM
MetallicaMatt's Avatar
I DD my Spec 5
402 rwhp, but at the track with the gas its 550+rwhp and 6000RPM clutch dumps
If I wasn't beating on it at the track, I would have gone Spec 3.
I've learned (quickly) how to drive it daily, but its not the most gentle.
but yes, whiplash
Old 02-14-2008, 11:13 AM
SPEC-01's Avatar
I have driven the stage 5 on the street...it can be done...but it is not intended to be a street specific set-up. Stage 5 uses a Sintered iron disc which is very soft in regards to material hardness. Because of this it will wear faster than a CSM (carbon-semi-metallic) disc and thus provide lower life expectency. What kind of power are you making? Let me know and I will be happy to provide a recomendation. Thanks!
Old 02-14-2008, 01:03 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
530rwhp motor, 830-880ish nitrous. I'm thinking spec 5 or dual disk?
Old 02-14-2008, 01:11 PM
Bad Blue WS6's Avatar
i run a spec 3 for street use,,i do not DD my TA,,,hooks very nice..i thought the spec 3 was rated for up to 600?
Old 02-14-2008, 01:18 PM
my opinion is once you start throwing sticky tires and hard launches at it, all ratings are out the door
Old 02-15-2008, 12:06 AM
The SPEC 5 grabs have enough the I slammed 2nd get and twisted a DS in two pieces and destroyed the 10 bolt
Old 02-15-2008, 08:50 AM
PewterScreaminMach's Avatar
I think the Spec 2 is often overlooked if you are making in the 400 range or less. The only reason I'd step up to the Stage 3 is if you race and hotlap a lot. The 2 doesn't like the hotlapping, but technically should have a longer life because of the kevlar friction material on both sides.
Old 02-15-2008, 09:05 AM
teke184's Avatar
slightly more street friendly clutch than the 5 would be the stg 4. still no springs so the engagement is pretty sharp, easing around parking lots or in traffic is not so fun.
but it does grab hard.....can't beleive my 10bolt is holding on with the 315DRs
but for what you need....stage 2 or 3....or throw on the LS7 with a lighter flywheel.
Old 02-15-2008, 09:11 AM
The reason I was asking is because there is one for sale by a member.
Old 02-15-2008, 09:15 AM
,,i just seen a thread with someone trying to sell a new Spec 3 +,,,,i will try to find it again....
Old 02-15-2008, 09:31 AM
https://ls1tech.com/forums/showthrea...highlight=spec
Old 02-20-2008, 07:49 PM
LS1TECH Sponsor
badpewter-z's Avatar
for more street and lower power get the 3, i love dmy stg3 great street manners and great mileage outta it. my stg 5 drives as smooth as glass right now after an extremely rough season of beatings it is harsh and very touchy on/off on the street . you get used to it but stop and go it may **** you off
as for the way mine is now, its toast so thats why its so smooth now , being replaced soon
Quick Reply: Spec 5 street, search down
