new clutch suggestions
Old 03-31-2008, 10:06 PM
stealth1281's Avatar
Default new clutch suggestions
well, it appears after my head/cam install, i'm in the market for a new clutch, seeing that my stock clutch sticks to the floor under high rpms. does anyone have any suggestions on what i should go with? thanks
Old 04-01-2008, 11:52 AM
thebart455's Avatar
i just bought my ram powergrip hd clutch rated to hold 600 flywheels hp what ever u do dont get a centerforce they are junk
Old 04-01-2008, 03:16 PM
Viper's Avatar
ClutchMasters stage3
Old 04-01-2008, 04:31 PM
BarneyMobile's Avatar
Amen to that!
Centerforce
Old 04-01-2008, 06:53 PM
thanks guys. I was actually looking at the Centerforce clutches, but it sounds like I should be looking elsewhere. By the way, my car is a DD with some track time. Should I be looking at a gm clutch?
Old 04-02-2008, 10:49 AM
hndakilr's Avatar
ls7 clutch package.
feels like stock yet grabs a lot better and can hold much more power
399 for the clutch pp and new flywheel(you will need) from scoggin dickey parts
sdparts.com
Old 04-03-2008, 08:28 PM
Originally Posted by hndakilr
ls7 clutch package.
sdparts.com
am i looking at the wrong ls7 package? $424.95
http://www.sdparts.com/product/SDLS7...cFlywheel.aspx
Old 04-03-2008, 08:33 PM
neeshSS's Avatar
tex 0z700 if you don't mind spending a little change. I've had it for a while, hasn't given me any troubles at all.
Old 04-04-2008, 02:41 PM
thebart455's Avatar
and i would HIGHLY and i do mean highly recommend that u go ahead and change the slave cylinder out had mine go out and my old clutch cooked
Old 04-06-2008, 06:11 PM
fsttruckin's Avatar
spec stage 1 grabs great good dd
Old 04-06-2008, 07:06 PM
LS1crazy01's Avatar
Another one here for the Ram. I have the Level 3 power grip and I love it but it sounds like you have a hydrolic issue and not a clutch issue. When my slave and master went out thats when I had the same issue. So what ever you get make sure you do the slave and master. I did a Ram clutch,Ram slave, and Ram Adjustable master witch you will NEED for any after market clutch. And also its a must to do the drill mod with an aftermarket clutch. Its even in the instructions from Ram. And Ram is the one that says you NEED to run the adjustable master. Good luck!
Old 04-06-2008, 07:18 PM
MrElectric03's Avatar
Whatever you do dont get a centerforce...my dual friction lasted 12k miles in a bolt on car. Now I bought a light metal disc for it because I am spending my money on a H/C swap and dont have the money for a new kit, when i do I am thinking about the Textralia
Old 04-06-2008, 07:45 PM
CARTEK Racing
WS6TransAm01's Avatar
I'd say get a CARTEK clutch.
It drives like stock on the street, pedal feel is almost like stock, and that ***** does hold the power like no other. I powershift mine at 7000rpm and launch damn near close to that on a ET Drag. Meanwhile, I drive it to and from the track, in traffic, and so on.
Just my $.02
