ls7 clutch part number?
hey guys quick question... is this the ls7 clutch kit part number?
M6 stock replacement LS6 clutch kit (flywheel, clutch, pressure plate) (from Z06) = 12570806
my clutch just went so i need to replace and i want to get the ls7 kit.
I've to dig it out from the grave for some questions. I've a 02 Formula M6 and I guess it's still using the oem clutch. Here's the question
1) Can I use the complete LS7 clutch kit (the one at sdparts.com) in my LS1?
2) If no, then I've to go LS2 flywheel and LS7 clutch. But what kinda pressure plate I should use?
LS7 pressure plate comes with the clutch kit. And the LS2 flywheel is the same at the one that comes wtih the LS7 clutch. I bought my LS7 clutch off of someone that took it off their crate motor. It all bolted right up to my car. Been running strong since last spring and is surviving the turbo's with no problems.
LS1TECH & Trucks Sponsor
Our kit will work fine for you, just give me a call.
-Jesse
-Jesse
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
searched in www.gmpartsdirect.com
there was no part found for part number 24238412.
the flywheel part number was fine
thanks
Part numbers have changed
__________________
The new number comes up in their system if you put in the old one. It's still cheaper through us, as they add on $82 shipping and with ours you get all new bolts with it.
__________________
My LS7 kit from you guys just arrived at my house. Everything looks good! Flywheel, pressure plate, clutch, and 12 bolts all included. Can't wait to get this thing installed!
