I am just nuts or did every Pro5.0 shifter install go like this?!?!?!!?
Old 05-18-2008, 05:52 PM
drummydummy's Avatar
Default I am just nuts or did every Pro5.0 shifter install go like this?!?!?!!?
Just finished installing my Pro 5.0 shifter with ws6store short stick. So far the shifting is fine and feels great! BUT......
with everything put back together, everytime i go into reverse, the nuts holding the shortstick onto the shifter bangs up against the center console on the right side. It bangs up against it EVERY time and bad enough to slightly shift the whole center console. not MUCH but its very noticable and very annoying.
I asked a friend who has had 3 Pro 5.0 shifters in THREE different f-bodys and says it happened to him too.
Does everyone else have this problem with their Pro 5.0 ?!?!?!?
Old 05-18-2008, 06:17 PM
iverson387's Avatar
buy an angled short stick. i have the lous short stick on my pro 5.0 feels great and doesnt hit
Old 05-18-2008, 06:22 PM
i have a black angled stick that i have too and i have the regular ws6 short stick. switching them does nothing. still bangs the console.
anyone else???
Old 05-18-2008, 06:41 PM
SladeX's Avatar
Try moving the shifter over to the driver's side a bit. A little movement at the base may go a long way at the stick.
Make sure the short stick is bolted onto the driver's side of the shifter. I haven't installed a pro 5.0 on my car, but I could swear the car's I've driven with a pro 5.0 haven't had any issues banging the console. My only complaint with them have been noise.
Old 05-18-2008, 07:24 PM
02NBMWS6's Avatar
Mine did the same damn thing no matter how I set it up, and believe me i tried hard to fix it.
Old 05-18-2008, 07:29 PM
camaroride32's Avatar
i had the same problem... i put the stick on the right side of the shifter, when its suppose to be on the left side of the shifter. Solved my problem w/ it hitting the console.
Old 05-18-2008, 07:33 PM
ttranssam's Avatar
yea angle the stick towards u... i made my own and love it but.....stock never hit. i love the shifter tho
Old 05-18-2008, 08:04 PM
well i just cut away some of the plastic underneath the tab it was hitting against and that seemed to help a bit. very minimal banging now.
the **** and short stick once all back together on the pro 5.0 in the nuetral postion still seems to sit farther over to the passenger side of the boot vs. the **** location on the stock shifter in nuetral
same with everyone else?
Old 05-18-2008, 08:25 PM
Omec's Avatar
i just got done w/ my swap and installed the ws6 store stick on an unknown shifter. only thing i had to do was get diff bolts so they werent sticking out so far when installed. w/ the bolts supplied it hit the inside of the console.
Old 05-18-2008, 10:25 PM
02 Camaro SS's Avatar
Haven't had that problem with mine with either the normal pro 5.0 stick of LSS.
Old 05-18-2008, 11:55 PM
HoLLo's Avatar
I'm not sure what shifter is in mine. I'm pretty sure it must be a Pro 5.0 but i cant tell.. It hits the console in 2nd and 4th sometimes, never for reverse or 6th for me though. With a straight short stick
Old 05-19-2008, 12:19 AM
The Big Shuck LS1's Avatar
seems completly normal. My 5.0 was pissing me off from hitting so i went back to hurst and its been fine since..
Old 05-19-2008, 12:31 AM
99Bluz28's Avatar
Lightbulb
I never had a problem with mine with the factory Pro 5.0 stick I cut down 1"; in over 8yrs.
Old 05-19-2008, 01:01 PM
dailydriver's Avatar
SAME here!
Is the Poncho console different from the Chevy maybe??
Quick Reply: I am just nuts or did every Pro5.0 shifter install go like this?!?!?!!?
