problem removing clutch master cl
http://www.installuniversity.com/ins...tar_washer.jpg
I cant seem to get it off, its like stuck, the metal plate that goes over the star washers. I can slide it but not much at all because it drags the threads on the bolts. eh
from the pics it looks like that bracket is still hanging there and I cant manage to find a spot where i can remove it since it looks like its part of teh clutch assembly
Replacing the master can be pain.
I know I just recently did it twice along with everthing else clutch related.
You have to get the star washer off and the metal plate is very
difficult to get out of the way.
You have to pry the metal plate out of the way.
I also removed the master cylinder bolts on the brakes to make more
room under the hood. Just moved it off to the side a bit.
ah i got it. Suprisingly only one of my bolts had a star washer?? weird. But i got the bracket off of the one bolt that had the star washer.. got the washer off.. put the bracket back on that bolt, then slid the master out from the engine side. I already had my fluid drained so I took off the resevior and pluged it with a bolt and a clamp so no fluid got anywhere cause the line had to go under the brake fluid resevior
yeh my metal bracket didnt get bent, i actually pulled out the master with the bracket still on the bolts.. so it couldnt have been bent since they slid right out. thanks for the help guys..
