6.0 Install with T56, What is different from LS1?
I have a 2003 6.0 out of a 3/4 ton truck, I want to hook it up to my T56 out of a 2001 Transam. The 6.0 has a flexplate, I need a flywheel, Can I use an LS1 Flywheel? Or even an LS7 flywheel and clutch setup?
So is all Gen 3 clutch and flywheel stuff interchangable? What about weighting and balancing and such? Will I lightweight LS1 flywheel and anyother Gen 3 flywheel work without issue? I know Gen 1's had some odd interchange BS.
I'm using all gen 4 ls1 parts and hardware for my T56 conversion. If you're talking about a light weight aluminum flywheel, I don't think those are for street use. I went with Centerforce 12 inch (not the 11 inch!) Dual Friction Clutch and steel flywheel.
Andrew
Are you guys sure? I went to install the ls1 flywheel and clutch and the clutch wont disengage because the ls1 crank sits flat to the rear cover and the 6.0 has a lip outside the cover which makes everything a inch or so further completely compressing the slave and putting pressure on the PP disengaging the clutch.
i think u have 2002 or 2001 6.0L there some kinna spacer in the rear of 6.0L u hav to take off not sure 03 have it. i have 02 6.0 i hav to take spacer on the rear of the block off mine does the same thing as ur did
