T56 Skip Shift Solenoid Delete Plug
Old 07-28-2008, 07:56 PM
the_merv's Avatar
Default T56 Skip Shift Solenoid Delete Plug
This is something I kinda engineered based on a little research..thanks to Amber as Six Speeds Inc for the CAGS Solenoid pics BTW.
I found that the Thread Pattern for the CAGS Solenoid was M20X1.5mm..found out as well that thread can be found as an Oil Drain Plug that is currently on the shelf at the local Orielly's. The Vehicle that uses that particular Drain Plug is a 1983-1986 Plymouth Horizon, 1.6l 4 Cyl.
After getting the pics of the Solenoid I found that the Threads were alot deeper than the Drain Plug. The biggest part that was holding up the Plug from going deeper was the Flange on it. I took out the good 'ole Dremel and took care of that. A little RTV and some Teflon Tape, I should be good to go. It's going to go in deep too..so hopefully it will seal itself with the part that I ground off..
Skip Shift (CAGS) Solenoid..
Oil Drain Plug with Flange ground off..
I figure this will look better on the side of the T56 than the un-used Solenoid..
Old 07-30-2008, 01:04 AM
bandit98's Avatar
Awesome idea. That'll keep the local T56 inspectors curious.
Old 07-30-2008, 02:49 PM
Libertysyclone's Avatar
does that one belong here?
Old 07-30-2008, 03:00 PM
bigsticksupra's Avatar
so what exactly does this do? what's wrong with leaving in the solenoid?
Old 07-30-2008, 03:25 PM
Viper's Avatar
+1 for ingenuity!
Old 07-31-2008, 09:28 AM
Z'mnypit's Avatar
Its the skip shift solenoid. Nothing wrong with leaving it in, its just kinda there not being used so why not remove it.
I did the same thing on mine, deleted the CAGS with HPtuners and removed the solenoid since it was just there in the way.
Old 08-06-2008, 12:33 PM
onebad82z's Avatar
I did this myself awhile back, but only posted my findings on the conversions board... didn't want to double post.
https://ls1tech.com/forums/conversions-swaps/851366-t56-swappers-cags-reverse-lockout-delete.html
Old 08-06-2008, 12:36 PM
onebad82z's Avatar
Yes it is.
Old 08-06-2008, 01:46 PM
the_merv's Avatar
https://ls1tech.com/forums/showthread.php?t=851366
That's where I found the thread spec.. thanks for the info.
I just modified it a little..that's why I posted pics.
Old 08-06-2008, 01:49 PM
onebad82z's Avatar
Excellent...
Old 08-18-2010, 08:42 PM
ARNOLI's Avatar
Thumbs up
there you go.... I saved time and money and my arm just to get the reverse-gear shifted.
thanks
Old 09-08-2010, 03:15 PM
ragtop73's Avatar
Has anyone else just modified the CAGS solenoid to create a plug that fits correctly. I have the oil plug and it is to short to thread in far enough. Plus, it is designed to work with a gasket, so you need the shoulder. Here are a few photos of the solenoid.
I cut the hex section 1/2" up and removed the solenoid. Cut off the inside shaft and tack over the center hole to seal it. The cap is not required, but it looked good.
Old 09-08-2010, 05:02 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
We sell an aluminum plug that is made specifically to delete the skip shift solenoid and will seal with the original o-ring. $15 plus shipping if anyone is interested.
The following users liked this post:
edster75 (09-05-2023)
Old 09-08-2010, 11:51 PM
99Bluz28's Avatar
I don't see it listed on the your website.
Old 09-09-2010, 12:46 AM
killagt's Avatar
what the hell is shift skip ? i saw it on my dash all the time, dont know what it for, i just shift normal.
Old 09-09-2010, 03:52 AM
Tobias05's Avatar
http://xse.com/leres/ss/cags.html
...the PO must have installed a skip-shift solenoid.
Delete the CAGS with software will turn off the light.
Old 10-22-2010, 11:27 PM
Circa307's Avatar
it is just hard to believe that lowes or HD doesnt carry a brass or aluminum plug that would fit into the CAGS hole. maybe even a reg bolt. i sure you guys have done research and thought about this already
Old 11-13-2010, 01:51 AM
the_merv's Avatar
It's a large metric thread, if they do I haven't seen it.
Old 11-24-2010, 08:37 PM
ragtop73's Avatar
I spent at least a full day searching the net and contacting specialty fastener companies.
The only other application (currently commercially available) for that thread seems to be oil pan plugs and the length of these is at least 1/2" to short to be sound. Please let me know if you find one that doesn't come with a one off price tag.
Old 11-24-2010, 11:31 PM
the_merv's Avatar
Ya kinda have to customize it..I've been using it this whole time without issue..the spot I grinded down kinda sealed itself in the case.
Bot-a-bing..
Quick Reply: T56 Skip Shift Solenoid Delete Plug
